need help! 95 LS b18b into a 99 civic EX?????
Old Jan 1, 2005 | 09:58 AM
The Civic Project's Avatar
Default need help! 95 LS b18b into a 99 civic EX?????
wlel i found a 95 b18b motor for sell it comes with a ys1 hydro tranny, what am i going to have to do to have this swap work for my car, i know my car is OBD2b so do i need to convert the whole wireing to obd1?. also will the mounts i have now work for the b18b and the hydro tranny? any help would be great
thanks
Old Jan 1, 2005 | 10:21 AM
Plugs's Avatar
Default Re: need help! 95 LS b18b into a 99 civic EX????? (The Civic Project)
repost!!
Old Jan 2, 2005 | 08:26 PM
tspkenneth's Avatar
Default Re: need help! 95 LS b18b into a 99 civic EX????? (ickabod)
I did the exact same swap a couple days ago and the motor will work with the tranny. You will need a 99-00 civic si rear tranny bracket and upper driver bracket from si also. YOu can use your stock harness but will need to buy a obd2b conversion harness to convert to obd1. Also you need to convert distributor, injector clips, and alternator to obd1, either that or get obd2 distributor, injector, and alternator. Someone correct me if im wrong
Old Jan 2, 2005 | 08:31 PM
VTECVillain's Avatar
Default Re: need help! 95 LS b18b into a 99 civic EX????? (tspkenneth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tspkenneth &raquo;</TD></TR><TR><TD CLASS="quote">I did the exact same swap a couple days ago and the motor will work with the tranny. You will need a 99-00 civic si rear tranny bracket and upper driver bracket from si also. YOu can use your stock harness but will need to buy a obd2b conversion harness to convert to obd1. Also you need to convert distributor, injector clips, and alternator to obd1, either that or get obd2 distributor, injector, and alternator. Someone correct me if im wrong</TD></TR></TABLE>
You are correct. About the engine harness, you MUST reuse the stock harness or only another 99-00 Civic engine harness. No other harness will work.
Jhicks
Aug 7, 2012 06:51 PM
NickW
Jul 30, 2011 06:54 AM
flyingduck04
Sep 15, 2005 08:32 AM
dgmorr
17
Sep 1, 2005 09:20 AM
The Civic Project
Jan 7, 2005 07:56 PM
