Ls motor in a 99 Si
Old Jan 1, 2005 | 09:16 AM
01-0720's Avatar
Default Ls motor in a 99 Si
my friend has a 99 si, the b16 is acting up burning oil and **** so were pulling it out and putting an ls motor in there while he builds the b16, i think hes doin an ls vtec, but anyway, we started pulling the b16 out and the b16 has one plug going into the distributer and the ls has two, theres a couple othere things
question is what do we do, what wiring harness do we use, what ecu, please help us out on what we need to do to put this ls motor in his si, it doesnt have run perfect, he needs it to get back and forth to school and work for a little while untill his b16 is ready
any tips whould be awesome
thanks for any and all help
Old Jan 1, 2005 | 09:24 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: Ls motor in a 99 Si (01-0720)
The ecu would be a P75 if I'm not mistaken, everything else should work(axles, linkage) the mounts might be different, I've never heard of anyone wanting to do this swap into an Si. You should be able to use the same wiring harness as long as the engine is the also the same OBD class as the Si(OBD2-B I think?)
Old Jan 1, 2005 | 09:32 AM
4potnick's Avatar
Default Re: Ls motor in a 99 Si (turtlecx92)
You will need obd2b ls ecu unless you convert to say obd1. You will use your original si harness and you may have to cut a couple harness clips from the ls motor and splice in the wires. Car might seem faster with the LS and motor and SI tranny due to powerband and gear ratio. good luck
Old Jan 1, 2005 | 09:42 AM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtlecx92 &raquo;</TD></TR><TR><TD CLASS="quote">The ecu would be a P75 if I'm not mistaken, everything else should work(axles, linkage) the mounts might be different, I've never heard of anyone wanting to do this swap into an Si. You should be able to use the same wiring harness as long as the engine is the also the same OBD class as the Si(OBD2-B I think?)</TD></TR></TABLE>
The ECU is the P2T and yes, all 99-00 Civics are obd2b.
Old Jan 1, 2005 | 04:22 PM
01-0720's Avatar
Default Re: Ls motor in a 99 Si (2000EM1)
we figured out most of the problems
the car has a obd11 to obd1 harness and a jdm obd1 b16 ecu
we dropping the ls in in the morning
and the motor is only goin in for a little while until the b16 head is built then, were gonna pull the ls motor, prepare the ls block for the ls/vtec and drop the ls/vtec in with the b16 trans
Old Jan 1, 2005 | 04:45 PM
tcr03's Avatar
i love my ls/vtec in my sol. you might want to upgrade the pistons and rods to accomidate the higher reving b16 head. i used gsr rods and pistons, and a gsr head. i also have the si tranny. you will def. notice a difference.
Old Jan 1, 2005 | 04:59 PM
01-0720's Avatar
Default Re: Ls motor in a 99 Si (tcr03)
yeah hes gonna use the b16 pistons, hes doin a bunch of stuff to it, it should be damn fast
Modified by 01-0720 at 6:49 PM 1/4/2005
Old Jan 3, 2005 | 12:17 PM
01-0720's Avatar
ok we got it in, but cant get it to start, will the ecu make it not start, were tryin to run a p30
Old Jan 3, 2005 | 12:35 PM
bogus_ek's Avatar
hmmm i don't think the p30 will start that. you might want to get an ecu out of an obd II ls, unless u got a conversion harness. if you do get a p75 that should start her up.
Old Jan 4, 2005 | 12:48 PM
01-0720's Avatar
Default Re: Ls motor in a 99 Si (bogus_ek)
ok we got it to start, we used the stock 99 si ecu, but is bogging hard core, wont rev above 3 grand, it keeps missing, we played with the timing a little
he has a vafc on the car, dump question but could that mess with it, i dinno im just trying to think of stuff
any suggestions on what to look for or what to change or fix whould be awesome
thanks
eric
redrusch
Sep 11, 2007 09:24 AM
detokrsi
Apr 26, 2007 08:24 AM
jdmsiblue1
Jan 30, 2006 06:06 PM
974drgs
Jan 27, 2005 05:45 AM
01-0720
Jan 5, 2005 05:36 PM
