1997 prelude DRL
Hey, i got a problem, first my drl light was always on and my lights worked fine. Then after about a mounth my passenger high beam quit, then a while after that my drivers side low beam quit and the passenger side high came back on. I went to a local honda dealer and one of the parts guys thought that it could be the drl relay but to see they would have to bring my car into the shop and charge me 2 hours labour. So my questions are, have any of you had this sort of problem and do you know what it is? and where is the drl relay located?
USDM Preludes doesn't come with DRL (Daytime Running Lights?) unless it's installed as an aftermarket option.
Never had that problem, did you check the grounding? are you on stock bulbs? time to troubleshoot.
my lude is USDM, but when i came here to canada i think they installed the DRL's on it but some how just removing the fuse dosent do it...help!! i want to get the DRL's off
