please help me please
Old Dec 31, 2004 | 01:29 PM
tat2ooood's Avatar
Default please help me please
I have a 93 del sol si d16z6. I got a helix power tower and put it on my car. after installing the car started jumping from 2000-3000 rmps. I decided to take it off the car. and went back to the origanal set up... now the car is still jumping from 1000-2000 rpms there are no CEL"S. I have no idea what is going on... thought I might have a vacuum leak or the map sensor was bad but seaming how there is now CEL"S I dont think it is that... I was told to drive the car and maybe the computer would reset itself and that didnt work.. So were do I go from here. could it be a vacuum leak... please help...
Old Dec 31, 2004 | 01:48 PM
99hatch's Avatar
Default Re: please help me please (tat2ooood)
what is a helix power tower?
Old Dec 31, 2004 | 01:49 PM
tat2ooood's Avatar
Default Re: please help me please (99hatch)
a throttle body spacer
Old Dec 31, 2004 | 01:52 PM
99hatch's Avatar
maybe there was a leak btw your throttle body and manifold
Old Dec 31, 2004 | 01:54 PM
tat2ooood's Avatar
maybe I will check that out
Old Dec 31, 2004 | 02:05 PM
Eugenestreetscene's Avatar
Yeah sounds like a vacume leak. Did you use new Honda gaskets for the coversion on both sides of the spacer?
Old Dec 31, 2004 | 03:39 PM
tat2ooood's Avatar
Default Re: (Eugenestreetscene)
I used the gaskets that were supplied with the spacer... Its to dark to check tonight I will check tommorow.. and let you know but it sounds right... I hope thats all it is
Old Jan 1, 2005 | 01:41 PM
tat2ooood's Avatar
Default Re: (tat2ooood)
ok I am not to sure that its what it is I have checked and now I am just so confused...
Old Jan 1, 2005 | 02:49 PM
xZeler8's Avatar
sounds like a vacuum leak...make sure you reconnected all your hoses...could also be an idle air control issue
Old Jan 1, 2005 | 02:50 PM
xZeler8's Avatar
Default Re: (xZeler8)
also...try disconnecting your battery for about 30 minutes then reconnecting it and starting the car, your ECU will be reset
Tegboii
Nov 30, 2016 12:28 AM
Morford3288
Engine Management and Tuning
Jul 14, 2013 08:17 AM
superhatchbackbros
Oct 7, 2006 11:07 AM
delslo
Mar 18, 2003 06:11 AM
ICantGoFast
Feb 5, 2002 08:29 PM
