Cylinder #4 blew...
Old Jan 7, 2002 | 01:22 PM
976's Avatar
976
New User
Default Cylinder #4 blew...
Yay, I blew my engine. Oh well, the new block now just has to be put in sooner. I was thinking of dropping a B16A, but now I decided to stay with the B21A1 engine. Anyway. I know it was my #4 cylinder, as I pulled the plug wire it was dripping oil, I have the roughest idle I've ever seen, and a total lose in power. It drives, but I don't want to tow it to the shop, I think it is about 20 miles away, do you think I can get my car there (backfiring) - or will it just seize up? I know it's a unpredictabe question to answer, but what do you think my odds are? Thanks...
Old Jan 7, 2002 | 02:03 PM
Crazydave's Avatar
Default Re: Cylinder #4 blew... (B21A)
suck it up and tow it
if you blow it up.. you will have to tow it anyways..
Old Jan 7, 2002 | 04:12 PM
dustin's Avatar
Default Re: Cylinder #4 blew... (Crazydave)
Mike has two B21A motors in his garage that he can't seem to find a buyer for if you are interested........
Old Jan 7, 2002 | 08:52 PM
mike's Avatar
H-T Order of Merit
B21a,
Let me know if you are interested.
Mike
Old Jan 7, 2002 | 08:54 PM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (mike)
Interested. How many miles, can I trust you, any mods? Thanks...
Old Jan 7, 2002 | 11:30 PM
mike's Avatar
H-T Order of Merit
email me, mike@rely.net
Old Jan 8, 2002 | 12:47 PM
Pliggity's Avatar
Is the B21a1 the oldschool Prelude motor?
Just curious. Good luck with the car.
Old Jan 8, 2002 | 12:54 PM
falcongsr's Avatar
What is this crap?
mike is a punk but you can trust him
Old Jan 8, 2002 | 01:30 PM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (falconGSR)
Well, s**t. I found a place in Lynwood, WA. They have a B20A5 (135 hp vs. B21A's 140 hp) for $575.00, plus $85.00 for gaskets. The engine is from japan, and has average of 40k miles. I guess I should get that engine, sell my parts, and get an EK (well, an USDM cx (EK)). I am kindof tired of a car that I have to deal with stuff like this. Companies just don't want anything to do with 88-91 preludes. No conversions or anything like that...
Should I even buy the gaskets - kindof a waste of money since the engine has only 40k or less miles?
Old Jan 8, 2002 | 01:57 PM
falcongsr's Avatar
What is this crap?
why are they offering you gaskets? that implies something is wrong or disassembled, no?
mike is a good source if he has what you're looking for.
Old Jan 8, 2002 | 02:34 PM
GSRwBOOST's Avatar
If you can't trust Dusin or Mike then I suggest moving out of this country, cause we don't want you living here...
You can trust Dustin or Mike fo sho!
Old Jan 8, 2002 | 09:36 PM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (GSRwBOOST)
WTF is your problem?
[Modified by B21A, 6:42 AM 1/9/2002]
Old Jan 8, 2002 | 10:04 PM
civicturbo's Avatar
Did you do a compression test yet?
I bet it's not blown! The oil on the plug wire is from the valve cover gasket gone bad.
Do a compression test first, OR remove the wire then remove the spark plug so the oil would go in the cylinder, clean the spark plug & wire real good, reinstall, fire up and let me know what it does!
I bet it's just a simple valve cover gasket your problem (under $50.00 parts and labor).
Good luck!
Old Jan 8, 2002 | 10:31 PM
dustin's Avatar
He's just messing around
Anyways, I am sure mike would give you a B21A for a LOT less than $575.
Old Jan 9, 2002 | 01:04 PM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (civicturbo)
Good luck!
The rings were already going, so I need to replace it anyway. I still would like to drive my car though. You think a blown gasket or maybe spark plug could cause the loss in power, rough idle, etc? Thanks...
I think my plan now is to fix it up nice, sell some stuff, then sell my car and get an EK, well, a USDM CX if you want to be up tight about it.
Old Jan 9, 2002 | 03:28 PM
civicturbo's Avatar
If your valve cover gasket leaks oil in to the sparkplug hole and the sparkplug wire is wet then you will not be firing on #4, therefore it's going to run on only 3 cylinders = rough running and missing = loss of power. It's just like you disconnected #4 and tried to drive around on only 3 cylinders.
You said that the sparkplug wire is covered with oil. I can't think of any other way the oil going in there (unless you can see a big hole on the valve cover). I've dealed with this issue before on a lot of cars.
Let me know after you dry up everything and fire it up.
I think you'll be fine. Good luck!
Old Jan 9, 2002 | 04:33 PM
S13 slide's Avatar
i had this problem too, it was just the o rings gaskets around the spark plug holes, went to acura and got new gaskets and problem solved. btw that place thats selling that motor wouldnt happed to be across the street from lynnwood acura would it?
Old Jan 10, 2002 | 10:17 AM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (bobo)
This is why I am on honda-tech sooo much. I love you guys! Your right, I'm going to go pick up some new gaskets today. I guess I'll save up for the swap, and find a cheaper price.
I'm not sure if it is across from Acura of Lynnwood, I've never been there - why do you ask - are they shadey? Thanks...
Old Jan 10, 2002 | 01:27 PM
John's Avatar
New User
yeah, oil in the spark plug housing is usually just the spark plug seals... i think they were only a few bucks a pop... replace them all while you're at it...
Old Jan 10, 2002 | 02:30 PM
976's Avatar
976
New User
Default Re: Cylinder #4 blew... (DunReit)
Didn't work... I replaced all of them, cost me like $12. Oh well. I even changed my plug wires back to stock, that didn't help. The piston rod or connecting arm must have broke, I know I have no compression their.
Old Jan 10, 2002 | 04:31 PM
BTR ALL MOTOR's Avatar
you can drive it with one cylinder not firing, but just be careful and dont push it at all......drive very very slow, and i would have a friend follow you just incase something happens
ekcivic9
Jan 13, 2011 11:43 AM
lsvtechatch92
Oct 30, 2009 06:29 AM
No-Gi
Jun 30, 2002 08:21 AM
blazin
Nov 19, 2001 04:39 PM
ringgold
Jul 10, 2001 12:57 PM
