Koni Yellows suck?
Old Jan 7, 2002 | 12:54 PM
96 SOHC VTEC's Avatar
Default Koni Yellows suck?
I have Koni Yellow adjustable shocks on my Civic and recently I was speaking with this guy who said that Koni shocks have to be rebuilt frequently in a short period of time. Has anyone ever heard of this or know what may cause this? Thanks
Old Jan 7, 2002 | 12:56 PM
RacerXI's Avatar
Default Re: Koni Yellows suck? (96 SOHC VTEC)
I know they can be rebuilt, but i'm not sure of the time in between. I'm sure it depends on how you use them and how low your car is. HTH.
Old Jan 7, 2002 | 02:18 PM
Geezer's Avatar
Default Re: Koni Yellows suck? (RacerXI)
Yep. You can kill any shock by running too much drop, and basically slamming the insides together by compressing the shock too much. But I don't think Koni has developed such an excellent reputation by having shocks that need to be rebuilt frequently. What did this guy suggest you run instead?
Old Jan 7, 2002 | 05:40 PM
Default Re: Koni Yellows suck? (Geezer)
He didn't really give me any suggestions, just told me that story.
Old Jan 7, 2002 | 05:46 PM
TurboSedan's Avatar
New User
Did he say which model of Koni shocks? Did he mean all Konis? I have yellows and they are awesome at damping the Integra Pro-Kits on my Civic.
Old Jan 7, 2002 | 05:54 PM
Kamin's Avatar
Default Re: Koni Yellows suck? (97CivicFerio)
do the yellows have good ride quality tho? someone told me its kinda bumpy even on the lowest setting.
Old Jan 7, 2002 | 06:24 PM
owen_the_soyboy's Avatar
and a great story it must hav ebeen.
they do need to be rebuilt often if they are run with too stiff a spring, or what was said above, they are allowed to bottom out. Koni makes a very durable shock, and compared to tokico and kyb, the Koni Yellows can handle a stiffer spring rate for a longer period of time without needing any rebuilding... so the Koni yellows are superior to the other common choices of the import crowd on a budget... and even to some choices of those not on a budget
Old Jan 7, 2002 | 06:33 PM
gamby's Avatar
Default Re: Koni Yellows suck? (owen_the_soyboy)
I bought my yellows because of Koni's reputation as on of the best shock manufacturers out there. Their race history speaks volumes of their quality.
I'm very happy w/ mine so far (installed them late summer). I'm using them w/ Neuspeed Sofsport springs (same rate as the sports, but a 3/4" drop) and I have them on the lower perch up front and middle perch out back, so the car is dropped about 1.75" up front.
Handling is great--body roll is almost nil. As for ride quality, even on the softest setting, they are pretty stiff. It os still compliant enough for a daily driver, but if you go over rough roads, you know it. Unfortunately 'performance' shocks are stiff.
hope this helps.
Old Jan 7, 2002 | 08:26 PM
Sohc Driver's Avatar
Default Re: Koni Yellows suck? (gamby)
umm...I have no complaints with my Koni Yellows..i am running them with Ground Controls...I have them medium in the front and stiff in the rear...not to bumpy...but then again..u sacrifcie comfortabiltiy with a sportier suspension..what do you expect....but if u do want to help eliminate this bumpiness...i would advise bigger profile tires...and higher ur car a little bit......I have rode in many suspension setups..they are all respectable..but not as good as Koni yellows...I have driven an EK coupe with KYB AGX and Skunk 2s...corners very good..but the car was very bouncy....even on smooth roads...it was a very wavey ride...i guess u could say...and my roomate has a DC coupe...he is running Neuspeed springs with Koni Reds..the nauseating bounciness is eliminated..however the handling does not compare to the Skunk set up and my set up....umm...as for the rebuilding...i have never heard anything from any forum..i get more people advising Koni's then complaining...i have heard similar problems with Tockico however...i do not know the details though..don't worry man..Koni Yellows are the cream of the crop...be happy u have them..I and many other people in this forum are. In suspension..the difference can be Chocolate and ****!!...he he..i love that saying...
Khoi
Old Jan 8, 2002 | 10:23 AM
Default Re: Koni Yellows suck? (Sohc Driver)
Well I am glad to hear that Koni's are cream of the crop. People praise the Koni Yellow more than any other shock on the forums I belong to so this comment made me wonder if this had happened to anyone else. I still think I bought the right shock for me.
Old Jan 8, 2002 | 10:53 AM
Phil B's Avatar
I have Koni yellows and Progress Springs (can't remember the spring rate right now). They're pretty stiff and I keep them on soft all around for daily driving.
Keep in mind, though, Yellows are only rebound adjustable. That may make a difference...
Mine ride nice and handle pretty flat and neutral, even with the rears set on soft.
The best part is, if you don't like the damping or they're wearing out, you can send them to Koni to be rebuilt for cheaper than getting new ones.
Oh yeah, I bought mine used. Two years old and they're still pretty nice.
Old Jan 8, 2002 | 11:32 AM
ImportechPerformance's Avatar
Default Re: Koni Yellows suck? (Barabus)
How much did you guys get your koni's for???
umm..i think they can be sent back for free...it will only cost ya on the shipping ....because Koni's have a lifetime warranty....correct me if i am wrong..but i've been told that and i think it says so on one of those certificate thingies that comes along with the shocks...
Khoi.
Old Jan 8, 2002 | 11:35 AM
i paid 560 for my Koni Yellows and 300 for my groundcontrols..brining my total to a respectable 860.....
Khoi
Old Jan 8, 2002 | 12:03 PM
I paid 500 for my Koni Yellows and 320 for my groundcontrols..
brining my total to a very comfy $820.
-Owen
Old Jan 8, 2002 | 12:15 PM
Phil B's Avatar
mine were 400 for shocks and springs, but used... doesn't really count.
As for sending them back, I'm sure if it's a warranty problem you can send them back for free, but I was talking about re-valving/rebuilding, not necessarily because they are broken. I think that costs.
Old Jan 8, 2002 | 01:02 PM
ToneyTigre's Avatar
New User
i paid $130 each. love my koni yellos, their the best mod i bought so far. where can i go to get it rebuild for future references?
Old Jan 8, 2002 | 01:05 PM
TurboSedan's Avatar
New User
Default Re: Koni Yellows suck? (ToneyTigre)
I paid $513 shipped from DiabloAutosports. I love them. They are rated to handle up to 500lb springs with no problems or premature wear out. My rates are 457/257. Peace.
Old Jan 8, 2002 | 01:11 PM
I payed $299 for my Ground Controls not including shipping and payed $508 to my door for the Koni Yellows. I think they are great shocks thusfar.
Old Jan 8, 2002 | 10:55 PM
nope..i heard they are rebuilt and revalved for free too....could be wrong still...im gonna start looking into this too.....we'll see...i really dunno..i am basing my reply from what i hear from my cousin, and he knows more about this than i do...
Old Jan 8, 2002 | 11:40 PM
HondaCivicEx98's Avatar
New User
koni will not rebuild ur shocks for free. their warranty dont warrant normal wear and tear. Why not dowload their catalog, they will have what is cover under warranty and what is not.
g3teg97
Jun 18, 2013 01:19 PM
bloodsweatntears
Suspension & Brakes
Jan 13, 2006 10:09 PM
VTcivic
10
Aug 3, 2003 12:03 PM
Thirty-Nine
10
Jun 29, 2002 07:12 AM
