Gsr swap into 93 hatch
Old Dec 30, 2004 | 11:05 AM
hatchfem's Avatar
Default Gsr swap into 93 hatch
Ok i know im going to make an *** of myself but i will be getting a gsr swap into my 93 dx hatch which as of now has an ls engine in there. Ive been told i need to change out the front rodors. Is this true ? Can i keep the stock rotors for now because i have hx wheels id like to keep?
Or are there any other things i can do ?
Thanks
Old Dec 30, 2004 | 11:07 AM
civicsisi's Avatar
Default Re: Gsr swap into 93 hatch (hatchfem)
no its not true. you can use all your old stuff.
Old Dec 30, 2004 | 11:09 AM
hatchfem's Avatar
Default Re: Gsr swap into 93 hatch (civicsisi)
thanx for the quick response
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Yea go back to whoever told you that and smack them.
Old Dec 30, 2004 | 11:54 AM
jdmhatch21's Avatar
Default Re: Gsr swap into 93 hatch (JDM_Ej)
you can use all of your stock stuff, i put a gsr into my 94 hatch which had an ls in it and i was dissappointed in what the differnce between the two motors was, i ran a 14.6 with the ls with cams and cam gears, and with the gsr ran a 14.5 with the same tranny which is a gsr true lsd.
Old Dec 30, 2004 | 12:13 PM
berettagtz117's Avatar
Default Re: Gsr swap into 93 hatch (jdmhatch21)
dAMN I run that in my 93 hatch w/ z6 motor w/ boltons. Actually Ran 14.6 @ 99 but that was because I was spinning my tires through third..
Old Dec 30, 2004 | 01:22 PM
Tank8677's Avatar
no, you dont need to change the rotor, u can use stock rotor. i have the same set up and i luv it.
92 eg hatch powered by b18c
ported n polished head
type r cams
ferra valves, titanium springs, and retainers
dc header
full catback
nkk stage 1 clutch
tein spring and tokico shocks
Old Dec 31, 2004 | 06:36 PM
hatchfem's Avatar
well do you guys think i should go for the gsr or just keep my ls some people have made me think that there isnt a big difference in the two except loosing torque by going with the gsr.
Oh yeah and im trying to go for all motor no turbo thats why i figured id do the gsr instead of ls.
tdubbebawllin
Jul 11, 2009 02:22 PM
boondocks1805
Oct 23, 2008 09:43 AM
rivoe302er
Sep 1, 2006 04:27 PM
primerk5
Mar 5, 2006 05:51 PM
yellowredR
Aug 9, 2003 11:40 AM
