Lower Ball joint removal and installation.
Old Dec 30, 2004 | 10:08 AM
Jazzersizer's Avatar
Default Lower Ball joint removal and installation.
Hi everyone,
I was just wondering if anybody has any experience with replacing the lower ball joint. I have to change mine tonight and I do have the tool required in the manual so is it pretty easy to do?
Old Dec 30, 2004 | 07:16 PM
strikeback03's Avatar
Default Re: Lower Ball joint removal and installation. (Jazzersizer)
I have no experience with the tool in the manual, the ratchet handle method has been good to me though. A standard puller and a hammer were ineffective.
Old Dec 30, 2004 | 07:31 PM
Tweakmeister's Avatar
I have the Honda tool, it kicks ***
I also bought a bunch of other Honda tools you're supposed to use...it's easier to take the entire assembly to a shop and have them press it.
Old Jan 2, 2005 | 12:15 AM
gt30typer's Avatar
Just call me Shade Tree mechanic
1. Put new ball joint in freezer
2. Take a MAP gas torch and heat the surrounding steel on the steering knuckle where the Ball joint is located.
(if it has a retaining clip remove that)
3. put the castle nut back on the ball joint and gently tap with hammer, if it is hot enough it should come out easily. Just make sure to not heat too close to the wheel bearing
4. take the cold ball joint out of the freezer and then tap it into the heated steering knucle.
BAM new ball joint , when it cools down it will be tight as hell and in there just like new
Old Jan 2, 2005 | 12:20 PM
Default Re: Lower Ball joint removal and installation. (gt30typer)
Old Jan 2, 2005 | 06:16 PM
cnydc2's Avatar
That sounds very easy
I was going to buy a press but that is an easy way without a press, will it work with bushing replacement
Old Jan 2, 2005 | 07:41 PM
MikeTV
Guest
Posts: n/a
Default Re: Lower Ball joint removal and installation. (cnydc2)
you dont need a press. it will come out with 3-4 good whacks of a hammer
Old Jan 2, 2005 | 07:42 PM
MikeTV
Guest
Posts: n/a
Default Re: Lower Ball joint removal and installation. (Eclipse spanker)
oh yeah, dont forget to take out the c-clip from the lower ball joint
Old Jan 2, 2005 | 08:47 PM
kuja's Avatar
3-4 good wacks !! ? I had to use a sledge and a fork. gt30 that sounds like a good idea tho :D
Old Jan 2, 2005 | 09:14 PM
cnydc2's Avatar
That pops the ball joint out of the spindle, but to remove it from the lower arm you will need the tool from Honda, do it the old fashion way and press it, or try what gt30typer did (to sounds very logical and should work with no problem.
Old Jan 2, 2005 | 10:09 PM
gt30typer's Avatar
nope , dont hit it on the ball joint itself, hit it on the side of the lower control arm where those wierd tabs are protruding , a few good raps and bam pop the ball joint is out. A little trick I picked up from my buddy at acura
ultraforce77
Jul 15, 2004 02:59 PM
2camsaam
21
Oct 1, 2003 07:32 PM
accordfreak
Jul 11, 2003 03:04 PM
Flamenco-T
Aug 21, 2002 11:49 PM
Mikey3000
May 7, 2002 10:23 AM
