lower ball joint removal
Old May 7, 2002 | 04:43 AM
Mikey3000's Avatar
Default lower ball joint removal
does the lower ball joint have to be pressed out of the knuckle by a machine shop or can i take it out myself? this is on a 92 civic cx if that matters.
Old May 7, 2002 | 05:07 AM
Malachi's Avatar
Default Re: lower ball joint removal (Boss Hogg)
you can do it yourself. http://www.c-speedracing.com/howto/b18cswap/swap.html
Old May 7, 2002 | 05:24 AM
CrxSi10's Avatar
If I were you, I would buy the ball joint remover from JC whittney for $16 (looks like the special tool in the helms manual). Looks and works way better then the fork like ball joint remover. I first used the fork like remover and busted the boot on the ball joint, and after hours of fustration and headache, I gave up and bought the remover from JC whittney. Arrived acouple days later, hooked it up and seperated the joint in seconds.
Old May 7, 2002 | 05:45 AM
Mista Bone's Avatar
D Tranny Guru
you can rent a ball joint press for FREE from Autozone.
Just remember to remove the lock ring before pressing.
Also a 3-5 lb BFH works just as good to get it out.
Old May 7, 2002 | 06:26 AM
Mikey3000's Avatar
Default Re: lower ball joint removal (Malachi)
i'm talking about replacing the ball joint. i need to get the top part of it out of the knuckle.
Mista Bone: are you saying i can hit the bottom of the ball joint to get it out of the knuckle?
Old May 7, 2002 | 10:23 AM
Chiovnidca's Avatar
Default Re: lower ball joint removal (Mista Bone)
GruvyTune
Aug 10, 2004 11:30 PM
ultraforce77
Jul 15, 2004 02:59 PM
accordfreak
Jul 11, 2003 03:04 PM
Flamenco-T
Aug 21, 2002 11:49 PM
97hb
Mar 9, 2002 11:31 PM
