wheels with +35 offset on EG
Old Dec 29, 2004 | 04:47 PM
simpleEdwin's Avatar
Default wheels with +35 offset on EG
will 16" wheels with a +35 offset have any problems fitting into an EG hatch? Will I have to roll the fenders etc?
Old Dec 29, 2004 | 07:57 PM
_BEN_'s Avatar
Default Re: wheels with +35 offset on EG (simpleEdwin)
How wide are they? If they are only 6~6.5 inches wide you should be ok but it will be close.
Old Dec 29, 2004 | 08:58 PM
16x7 =\ .... u think itll rub?
Old Dec 29, 2004 | 09:20 PM
_BEN_'s Avatar
Default Re: (simpleEdwin)
for 16x7 you want to run 40~42 offset. Its only 5mm difference so they probably would still look ok but you may have rubbing issues and you will definitely have issues if your sporting 215 or wider tires.
Old Dec 29, 2004 | 09:23 PM
cxSHOE's Avatar
if you are using a 16x7 rim with a 205/45/16 tire and you are lowered 1-2" you will have rubbing issues at full lock or turning into a driveway (turning wheels slightly half turn) as you go up the bank.
stick with +45 if you can. and you'll be fine.
Boostage
Sep 1, 2004 08:42 AM
yusoslo
13
Mar 11, 2004 09:45 AM
EP3-R
Jun 25, 2003 01:58 PM
ochdog
Jun 5, 2002 05:07 PM
MikeD
Jul 24, 2001 09:05 AM
