vtec oil pressure switch and the vtec solenoid plugs....
Old Dec 29, 2004 | 02:28 PM
1.8's Avatar
1.8
Default vtec oil pressure switch and the vtec solenoid plugs....
will i get a CEL if these aren't hooked up? motor is non-vtec. but using an EX engine harness. DOHC.
and the knock sensor plug isn't hooked up either. LS=no knock sensor.
CEL or not?
Old Dec 29, 2004 | 02:37 PM
hayabusa160's Avatar
Default Re: vtec oil pressure switch and the vtec solenoid plugs.... (1.8)
depends what ecu u running if the ecu look for those then you will get a cel if not ur cool
Old Dec 29, 2004 | 02:41 PM
1.8's Avatar
1.8
Default Re: vtec oil pressure switch and the vtec solenoid plugs.... (hayabusa160)
OBD1 ECU. so it won't look for it. i'm clean then?
Old Dec 29, 2004 | 02:44 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 ECU. so it won't look for it. i'm clean then? </TD></TR></TABLE>
Negative. If its a VTEC ECU, and theres no wire from the VTEC OPS or Solenoid, then it'll throw a CEL. I'm assuming you're running a B18B, so get an OBD1 LS ecu.
Old Dec 29, 2004 | 02:45 PM
1.8's Avatar
1.8
Default Re: vtec oil pressure switch and the vtec solenoid plugs.... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Negative. If its a VTEC ECU, and theres no wire from the VTEC OPS or Solenoid, then it'll throw a CEL. I'm assuming you're running a B18B, so get an OBD1 LS ecu.</TD></TR></TABLE>
yeah, sorry....i forgot to put that i'm using a OBD1 LS ECU.
so no cel, right?
Old Dec 29, 2004 | 02:50 PM
Risky Business
so no cel, right?</TD></TR></TABLE>
Old Dec 29, 2004 | 08:45 PM
del5ol's Avatar
no cel but u could cut the knock sensor plug off and send it my way
Old Dec 29, 2004 | 08:51 PM
HatchEh2's Avatar
gotta love the originality
b20forlife
Jan 9, 2012 03:08 AM
91EF_Si
Sep 21, 2007 05:52 PM
blinger
Apr 27, 2007 02:27 PM
rockinTheDOHC
Mar 30, 2007 03:11 PM
3.504
Oct 4, 2005 11:26 AM
