vtec oil pressure switch and the vtec solenoid plugs....
will i get a CEL if these aren't hooked up? motor is non-vtec. but using an EX engine harness. DOHC.
and the knock sensor plug isn't hooked up either. LS=no knock sensor.
CEL or not?
CEL or not?
Risky Business
Re: vtec oil pressure switch and the vtec solenoid plugs.... (1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 »</TD></TR><TR><TD CLASS="quote">OBD1 ECU. so it won't look for it. i'm clean then? </TD></TR></TABLE>
Negative. If its a VTEC ECU, and theres no wire from the VTEC OPS or Solenoid, then it'll throw a CEL. I'm assuming you're running a B18B, so get an OBD1 LS ecu.
Re: vtec oil pressure switch and the vtec solenoid plugs.... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Negative. If its a VTEC ECU, and theres no wire from the VTEC OPS or Solenoid, then it'll throw a CEL. I'm assuming you're running a B18B, so get an OBD1 LS ecu.</TD></TR></TABLE>
yeah, sorry....i forgot to put that i'm using a OBD1 LS ECU.
so no cel, right?
so no cel, right?
Risky Business
so no cel, right?</TD></TR></TABLE>
gotta love the originality
b20forlife
01-09-2012 03:08 AM
rockinTheDOHC
03-30-2007 03:11 PM
