Cam pin hoels don't line up with "up" marks
Old Dec 29, 2004 | 01:18 PM
inline4's Avatar
Default Cam pin hoels don't line up with "up" marks
I have a b18a and just did a headgasket, waterpump, timing belt change on it. Followed the instructions of the Helms, but at the end of the timing belt page, I could not get the pin holes on one of the cams(intake), to line up with the up mark. Is it possible that while removing the cam sprocket that it tweeked the alignment a little? When putting the 5mm punch into the pin holes, shouldn't the up mark be up instead of a little bit to the side? The key was in place too. so that's not the problem. Help ...
P.s. does anybody else know a way of setting the cam timing by eye without using the up marks.. maybe if i should put a 5mm in both pinholes and put the belt back on it will work? My car idles like cr*p and bogs uner 2500 rpms.
Old Dec 29, 2004 | 02:53 PM
projectTeG's Avatar
Default Re: Cam pin hoels don't line up with "up" marks (inline4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4 &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18a and just did a headgasket, waterpump, timing belt change on it. Followed the instructions of the Helms, but at the end of the timing belt page, I could not get the pin holes on one of the cams(intake), to line up with the up mark. Is it possible that while removing the cam sprocket that it tweeked the alignment a little? When putting the 5mm punch into the pin holes, shouldn't the up mark be up instead of a little bit to the side? The key was in place too. so that's not the problem. Help ...
P.s. does anybody else know a way of setting the cam timing by eye without using the up marks.. maybe if i should put a 5mm in both pinholes and put the belt back on it will work? My car idles like cr*p and bogs uner 2500 rpms.</TD></TR></TABLE>
iuno but i have the same problem
Old Dec 29, 2004 | 04:36 PM
Scott_Tucker's Avatar
It sounds like your intake cam is retarded 1 tooth by that description.
Old Dec 29, 2004 | 09:28 PM
inline4's Avatar
Default Re: Cam pin hoels don't line up with "up" marks (AutoEng2002Si)
thanks for the info..
anybody else have any info?
Dased530
Aug 7, 2005 04:52 PM
mdiym13
Apr 11, 2005 07:27 PM
JDMlyfestyle
Nov 24, 2004 04:48 PM
lazykiwi
Apr 17, 2004 11:12 AM
keebler65
Mar 31, 2002 12:24 PM
