dropped alignment
anywho i got my camber and what not aligned couple months ago after lowering my fronts. My rears were still on stockies due to a broken LCA bolt. So after 3 months i got my rears done. Now i also lowered my fronts another 1/2 to an 1 inch. and dropped the rears 3 inches. i went to get my car realigned at Sears and they wont do it...its to low..which it isnt....the car handles great. camber seems ok. do i even need to get it readjusted and waste another 50? i know you cant really eye it. but i dotn want to waste another 50 if i dont have too.....and yes my *** end is ******* bouncy almost like a pogo stick....good struts will solve this? oh ont sure if it matters but i do have a camber kit in the front.
yea the first time i dropped it my camber was off like i forget what degree but it was about 3-4 inches camber. i wetn through new tires in 2 months...inside completely bald outside still had teh stubbles
camber is not your tire's enemy. it's toe in or out. that will chew up your tires 100 times faster than camber. If no alignment shop will do it, take it to a local community college with alignment course. They usually have good equipment, and will align anything they can get on the rack.
hope this helps... good luck
sears probably means that its too low to get on the alignment rack, the rack is a couple of feet off the ground and has a steep up ramp my crx cant go on one, i bring mine to a race shop that does it with some lazers and some levels and this string thing, dont know what it is but the alignment comes out perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locovirus »</TD></TR><TR><TD CLASS="quote">well i meant i had 3-4 inch toe out? like / \ i guess?</TD></TR></TABLE>
3-4 inches toe out? Holy crap. How is that possible without bending something? I have 1/8 inches tow out by comparison. BTW, toe out refers to the leading edge of the wheels. I can't tell if it's \ / or / \ because it depends on which way the car is facing (up or down).
If you are happy with the camber, you can adjust the toe yourself. Check out threads like this and see if you want to give it a shot:
https://honda-tech.com/zerothread?id=811387
There are a few other methods out there but I like this one.
hey loco, i had the kyb's on my g/f civic with 3" of drop and they bounced more then ther stock shocks. they say only 1 1/2" to 2" of drop and thats all maybe 2 1/2". maybe some knows sumthing i dont but like said kyb's busted on my @ 3". when i low my CRX im 4" total and puttin in the stiffest spring i can find
ARGH!!! ok then thats down teh drain....if the kyb busted how about teh illuminas(SP?) from tokico. i was thinking if im about to spend 400 on just struts i should just go ahead and get the omnis.... what cha think? i dont want.....but damn it!
TOO MUCH TORQUE
Suspension & Brakes
Aug 14, 2010 08:59 AM
