F22B sohc vtec swap into CD5 Lx, problem.......
Old Dec 28, 2004 | 05:52 PM
precord96's Avatar
Default F22B sohc vtec swap into CD5 Lx, problem.......
Hey guys doing a jdm F22B(sohc vtec) auto into a CD5 accord lx automatic.
Everythings done, but the car has trouble starting and staying on.
I've been thinking it was several things, so I replaced the distributor, alternator, map, egr, spark plugs, fuel rail/injectors/fpr, but most of this I took off the running F22B2 engine. The timing was set at 15 degrees and double checked, I then pulled the covers off to check the TB and all the sprockets to see if everyting was lined up at TDC, and it was. I also check the firing order over and over again. I checked it at TDC with the dizzy cap off and made sure it pointed to the #1 cylinder and followed the 1-3-4-2 firing order.
The thing is that there are no cel's. When the car is running it bogs badly and the check engine will flash for a quick second as the car bogs, but no cel's are stored on the ecu.
Btw I dont have the O2 in the exhaust because there's no bung in the exhaust for it. I was thinking the car would be driveable to the muffler shop without it in the exhaust. It's plugged in, but dangling off the bottom of the car.
I think i've tried just about everything, and I'm up for any suggestions you guys might have. I'm baffled...
Thanks in advance.
Old Dec 28, 2004 | 06:55 PM
precord96's Avatar
Default Re: F22B sohc vtec swap into CD5 Lx, problem....... (precord96)
Just tried using the LX ecu and the car starts easier, but still bogs. Drove it around the block and its a little more driveable.
Also the tach is going crazy, it's not smooth and jumps erratically. Maybe that will help more....
Old Dec 29, 2004 | 05:58 PM
precord96's Avatar
bump
anyone?
Old Dec 29, 2004 | 07:41 PM
95ACM's Avatar
First thing, if its a JDM F22 it is non-vtec DOHC, but sounds like you have a USDM F22B1 SOHC vtec out of a 5th gen Accord EX.
My guess is it's the O2 sensor, but can't be too sure since i've never driven without it in the exhaust.
Old Dec 30, 2004 | 09:47 AM
precord96's Avatar
Default Re: F22B sohc vtec swap into CD5 Lx, problem....... (95ACM)
It's a JDM F22B, single cam vtec.
I'm gonna try some new plug wires today and see how that works.
OLD_HATCH
Apr 14, 2009 04:15 AM
civictype-r
Apr 15, 2006 01:39 PM
pghtrainer27
Nov 9, 2005 04:14 PM
Root79
Jun 6, 2005 12:05 AM
.(Lazarus).
Aug 25, 2002 11:48 PM
