FAN Help!!
Old Jan 6, 2002 | 09:55 PM
EddieHatchBlack's Avatar
Default FAN Help!!
anyone knoe how to wire one of my Fans to turn on (the INTAKE side, passenger) to a switch so i can turn it on and off. I heard this is possible, and would like to knoe how. If its not possible, than sorrie for wasting your time.
I have a 97 honda civic dx hatchback.
all help appreciated.
eddie
Old Jan 7, 2002 | 05:06 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: FAN Help!! (djeddiebear)
simple, goto thermostat housing and find fan switch. Wire in a switch that will create a circuit between those 2 wires. I used a simple 10 amp switch and 16 gauge speaker wire.
Make sure you find the right wires FIRST!
Old Jan 7, 2002 | 05:13 AM
cjames235's Avatar
Default Re: FAN Help!! (Mista Bone)
why would you do that? i dont understand
Old Jan 7, 2002 | 10:47 AM
94civicx's Avatar
New User
Default Re: FAN Help!! (cjames235)
i agree with cjames. What is the purpose of having the fan wired so it can be turned on manually?
Old Jan 7, 2002 | 02:13 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: FAN Help!! (94civicx)
that way you can cool down engine while in staging lanes.
Also while idle in traffic, 95 degrees outside, A/C blasting, fan running manually, water temp will stay at 180-185 degrees instead of cycling at 210 degrees.
[Modified by Mista Bone, 6:14 PM 1/7/2002]
Old Jan 7, 2002 | 02:24 PM
Spade's Avatar
And Mista Bone gets the cookie!!!!
Simple answer would be to keep the engine cooler.
Old Jan 8, 2002 | 04:54 AM
Mista Bone's Avatar
D Tranny Guru
then follow my suggestion.
julioboostamante
11
Jul 23, 2010 10:28 AM
rick_rabies
Engine Management and Tuning
Aug 21, 2009 05:20 AM
blaster834
Sep 16, 2004 11:52 AM
st0nedstoopid
Jul 11, 2003 12:19 AM
