Removing the roll pin
haha..i feel you on that, it always sounds so easy.
basically find something thats about the size of the pin and just work on it.....it'll prolly take a while....but just keep tryn to till the **** comes out.
ahhhh The roll pin, AKA the Bitch pin. use a roll pin punch, its diffrent then a regular punch. it has a nub at the end that should sit in the pin, and pop with a hammer, and ur free.
i removed my motor and tranny to get it out.
seriously though, just get a roll pin punch from matco or snapon or craftsman or whoever.. craftman is probably the cheapest.. just use that and a big hammer and punch it out.. you might have to get at it from the top due to not being able to get enough swing from the bottom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis »</TD></TR><TR><TD CLASS="quote">I used a tapered punch and a BFH. It was a little difficult but it was still a 30 second job. I don't see the big deal.</TD></TR></TABLE>
Thats exaclty what i did and it came out without a problem. BFH .. best tool in my box
I can do it with a screw driver, some extensions to hit it from the top around the engine bay and a hammer. The easiest part is getting it back in. Also, when you hit it out, make sure you know where it goes or you will be hating yourself later.
I find the easiest way is with a a/c compressor mounting bolt. Its tappered and fits in the end of the pin nice. Use a small sledge hammer and one or two strikes and its out. Thats it!
You need a Roll Pin Punch, 8mm or 5/16", and IT NEEDS TO HAVE THE NUBBY ON THE END! That little nubby keeps the punch centered on the pin.
On thing to keep in mind with the Bitch Pin, 90% of you efforts will go into making it move the first 1/16", the rest of the way is pretty easy. Be prepared for a good 5 minutes of nonstop whacking with the biggest hammer you can use.
Don't forget your saftey goggles too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxpaulcpxx »</TD></TR><TR><TD CLASS="quote">You need a Roll Pin Punch, 8mm or 5/16", and IT NEEDS TO HAVE THE NUBBY ON THE END! That little nubby keeps the punch centered on the pin.
Don't forget your saftey goggles too!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX »</TD></TR><TR><TD CLASS="quote">I can do it with a screw driver, some extensions to hit it from the top around the engine bay and a hammer. The easiest part is getting it back in. Also, when you hit it out, make sure you know where it goes or you will be hating yourself later.</TD></TR></TABLE>
This is what I ended up doing. Worked great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock-n-drop »</TD></TR><TR><TD CLASS="quote">Where can you buy a new pin at ?</TD></TR></TABLE>
Your local Honda/Acura Dealership.
I used https://honda-tech.com/zerosearch and then I used a cutter to cut the shift linkage off cause I couldn't get the pin out. hehe first time pulling out a motor.
No I use a air hammer. Man Minnesota rust likes to creep in on that little bitch pin and make it sieze up.
Nonetheless this topic has been covered probably a hundred times.
Search "Bitch Pin" or "Roll Pin" you WILL find it.
z6hatchboy
16
Aug 6, 2009 07:59 AM
