electrical system: DEAD?
Old Dec 27, 2004 | 03:43 PM
nomotorsol's Avatar
Default electrical system: DEAD?
quick (probably stupid) question:
battery was hooked up (both terminals) and had a kid "arc weld" my strut bolt with the wire running off the + terminal line on the harness that has an end where a bolt passes through (no clue what the correct term for that is). i'm sure it sent a surge through the electrical system or something bad because now i have no electrical power at all. i turn the key to on, nothing happens. i can't roll up my windows, no lights anywhere, no sounds from anything turning on. dead.
could it be a relay or a fuse that might be blown from the little incident that needs to be replaced? no idea what's up here, someone has to know
thanks
Old Dec 27, 2004 | 04:14 PM
2lua's Avatar
Default Re: electrical system: DEAD? (nomotorsol)
check the 80amp fuse. underhood fuses panel. it located near the battery.
Old Dec 27, 2004 | 04:25 PM
_Cyclone_'s Avatar
Default Re: electrical system: DEAD? (2lua)
Yeah, check that fuse... it's labelled BAT (80A). That will probably be blown... hopefully that blew before the ecu fried...
Old Dec 27, 2004 | 05:42 PM
nomotorsol's Avatar
Default Re: electrical system: DEAD? (CycloneBlue_1.6EL)
thanks
HotImportNightHonda
14
Oct 10, 2024 12:34 PM
bluestd
Sep 12, 2009 05:02 PM
Gvis420
Sep 18, 2008 06:28 AM
bennjamin@ozhonda.com
Sep 4, 2006 05:20 AM
FastHatch90
Apr 3, 2006 07:47 PM
