Leaking OIL!!!
Old Dec 26, 2004 | 08:41 PM
NVturbo's Avatar
O.G. triple O.G.
Default Leaking OIL!!!
As of late I have noticed some oil literally "spraying" from a needle-size hole in my downpipe onto my IC piping. And ever since last Wednesday, the damn oil pump seal has started to freakin leak oil also. Could this be related to the low OIL pressure I am getting (0 psi @ idle...but gradually moves up when revving)? Any help would be appreciated?
Old Dec 26, 2004 | 10:14 PM
adseguy's Avatar
Default Re: Leaking OIL!!! (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">As of late I have noticed some oil literally "spraying" from a needle-size hole in my downpipe onto my IC piping. And ever since last Wednesday, the damn oil pump seal has started to freakin leak oil also. Could this be related to the low OIL pressure I am getting (0 psi @ idle...but gradually moves up when revving)? Any help would be appreciated? </TD></TR></TABLE>
I think most people will tell you 0PSI at idle is not good and you should have checked the oil pump a lot sooner . GL with whatever happened
Integritycaptain90
Dec 22, 2007 07:26 PM
Takashi1978
Feb 23, 2006 06:21 AM
hatchinprogress
Jan 7, 2006 07:48 AM
92civichatchsir
32
Aug 28, 2005 03:10 PM
RemerLex11
May 15, 2005 02:35 PM
