Friends hatch with b18c throwing code 41....help??
He has a 92 hatchback with a 95 gsr swap that just got put in..he needed a new ecu so he got this one: 37820-P72-00341 (95 gs-r)
i dunno if it threw this code before, but the cel is throwing a 41: Primary oxygen sensor heater ...can anyone explain this one to me a little bit more? im not a pro at the cel codes...thanks!
Yup most likely need a O2 sensor.
you can reset the ecu 2 ways
1. pop ur hood. and go to the under hood fuse box. pull the back up fuse for 30s- 1 min. then put the fuse back in
2. disconnect the Negative battery terminal for 30s- 1min.
JDM_SOHC
31
Aug 18, 2005 06:10 AM
