B20B-Vtec Valve Clearance (stock bottom end)? Cam options?
Old Dec 25, 2004 | 08:58 PM
The Destroyer's Avatar
Default B20B-Vtec Valve Clearance (stock bottom end)? Cam options?
Hey guys, I was really going to turbo it. But the more I think about it, the more I want to stay away from boost on the B20. I have a B17 head without cams and am not sure what to go with in terms of power.
Im not looking for peak numbers at all. Im going to keep the stock rev limit or near it, seeing as how the b20 doesnt like to be revved and plus the rod bolts.
Now iv read about people running ITR cams and have been successful without opening the valve reliefs. Now if im going to keep stock compression and a low redline, would the ITR cams even be worth it? Should I just go with B16 or GSR cams?
Thanks for the help,
Eric
PS. Merry Christmas everyone.
Old Dec 26, 2004 | 07:10 AM
Default Re: B20B-Vtec Valve Clearance (stock bottom end)? Cam options? (Vtaaak y0)
Anybody?
Old Dec 26, 2004 | 07:14 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">
Now iv read about people running ITR cams and have been successful without opening the valve reliefs. Now if im going to keep stock compression and a low redline, would the ITR cams even be worth it? Should I just go with B16 or GSR cams?</TD></TR></TABLE>
Clay the motor, that will tell you right away.
Old Dec 26, 2004 | 07:37 AM
Default Re: B20B-Vtec Valve Clearance (turbogixxer)
We will clay the motor.
Its just im not sure what cam I should get. I dont want to buy a set of cams and when we clay the motor, the valves hit the pistons.
Old Dec 26, 2004 | 08:11 AM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, I was really going to turbo it. But the more I think about it, the more I want to stay away from boost on the B20.</TD></TR></TABLE>
Haha score one for me! j/k
Old Dec 26, 2004 | 12:21 PM
Default Re: B20B-Vtec Valve Clearance (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
Haha score one for me! j/k </TD></TR></TABLE>
Dont worry man, the next car will definately have a nice GT32 on it.
Old Dec 26, 2004 | 12:34 PM
EKhatch's Avatar
Default Re: B20B-Vtec Valve Clearance (Vtaaak y0)
The motor I helped with was a B20Z bottom end with a GSR head and JUN 3 cams. The intake valves were barely hitting and the valve pockets needed opened up a bit. This was with the gears set at 0deg and we never messed with them.
I know that doesn't help a great deal but that is just my experience. Good luck with the build.
Old Dec 26, 2004 | 12:40 PM
Default Re: B20B-Vtec Valve Clearance (EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">The motor I helped with was a B20Z bottom end with a GSR head and JUN 3 cams. The intake valves were barely hitting and the valve pockets needed opened up a bit. This was with the gears set at 0deg and we never messed with them.
I know that doesn't help a great deal but that is just my experience. Good luck with the build. </TD></TR></TABLE>
Everybit helps man.
Ill have a B17 head (same cast as b16) So imthinking there might be more room than a GSR head. And if im using a lower lift than a JUN3 and the compression is about a point lower, I think I can get away with it.
I wanna see who has what and what they did to go about this. We will clay the motor, but I want to hear other success/fail stories.
Old Dec 30, 2004 | 10:08 PM
Back from the dead for some info.
Im hoping to break 165whp with the shitty 8.8 compression ratio.
Old Dec 31, 2004 | 07:41 AM
geoscranny84's Avatar
we did my boys b20b....notched out the pistons and put a gsr head with jun 3 cams in it.............running very hard....he has to be putting down 205
francia661
Jun 8, 2012 08:18 PM
b20vtecturboeg9
Oct 22, 2009 03:23 AM
EK Dave
13
Jul 25, 2007 11:43 AM
rex_racer728
Oct 14, 2005 04:08 PM
madhatch
Sep 2, 2003 01:22 PM
