Anyone using an OBD1 Ignitor in a OBD0 dizzy?
Old Dec 25, 2004 | 10:27 AM
*Boostwerks*'s Avatar
Default Anyone using an OBD1 Ignitor in a OBD0 dizzy?
EDIT: For anyone interested, or for future Search info...the OBD1 Ignitor works perfectly fine in the OBD0 Distro. I used a 95 GSR ignitor into my A6 distro...works great!
Modified by Bryson at 11:53 PM 12/28/2004
Old Dec 25, 2004 | 02:49 PM
Bump
Old Dec 25, 2004 | 03:02 PM
91civicDXdude's Avatar
why dont you try it out since you have both
Old Dec 25, 2004 | 03:12 PM
Oh I dunno...don't really want the distro to light up in flames.
Old Dec 25, 2004 | 04:02 PM
crxgsr91's Avatar
Default Re: Anyone using an OBD1 Ignitor in a OBD0 dizzy? (Bryson)
I hope they are the same (they look the same) I swapped mine out a few months ago.
Old Dec 25, 2004 | 04:03 PM
Default Re: Anyone using an OBD1 Ignitor in a OBD0 dizzy? (crxgsr91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">I hope they are the same (they look the same) I swapped mine out a few months ago.</TD></TR></TABLE>
Oh really?...your cars running fine?
I read in another post that it has a different resistance or something?
Old Dec 25, 2004 | 04:15 PM
crxgsr91's Avatar
Well lets just say it don't run any worse . About the same.
Old Dec 25, 2004 | 04:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">Well lets just say it don't run any worse . About the same.</TD></TR></TABLE>
Well whats the issue? Same how?
Old Dec 25, 2004 | 05:28 PM
crxgsr91's Avatar
Here are some links to my old posts about the problem if you have any suggestions you can im me or post here.
https://honda-tech.com/zerothread?id=975639
https://honda-tech.com/zerothread?id=1055677
Old Dec 27, 2004 | 10:20 PM
Well for one...
You did a OBD0-OBD1 conversion right?
Well, make sure your distro is a OBD1. The OBD0 has a different amount of points for the pick ups, and will not work properlly. I'm almost sure thats your problem.
BUT...I wanna know if I can run an OBD1 Ignitor in my OBD0 setup...
BUMP FOR ANYONE???
Old Dec 27, 2004 | 11:13 PM
Redline130's Avatar
Default Re: (Bryson)
It should work fine. I've used ignitors out of OBD2 distributors in OBD0 distributors with no problems. I'd have to say an OBD1 ignitor will work the same.
Old Dec 27, 2004 | 11:22 PM
Sweet *** sweet.
I'll give it a try tommarow, and post the results...
Old Dec 27, 2004 | 11:44 PM
crxgsr91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Well for one...
If you were talking to me it is an OBD-1 Dizzy. Apparently it is off an integra LS or it is some sort of hybrid dizzy that locash racing made.
Old Dec 28, 2004 | 09:53 PM
Bump for my findings...
It works great!
Old Dec 28, 2004 | 10:40 PM
Redline130's Avatar
Glad you can get your car going again.
killrB
Feb 23, 2008 08:43 PM
ludesrv
May 12, 2007 08:58 PM
turbob16ef
Dec 31, 2005 07:09 AM
PaImportTuner
Sep 21, 2005 04:44 PM
slvrstns2000
Nov 18, 2003 06:23 AM
