b16 sleeved 85mm bore + type r crank and rods = high reving 2L engine?
Old Dec 25, 2004 | 07:47 AM
Rice Is Best's Avatar
Default b16 sleeved 85mm bore + type r crank and rods = high reving 2L engine?
i calculated that a sleeved b16 block with a 85mm bore with a type r crank would equal to 1979cc (2L)
so my question is. by keeping the type r crank and rods, the 2L b16 engine would still be able to rev up to 8500rpm. is this correct? the r/s ratio is still the same just bigger displacement.
dont ask why not just sleeve the b18c block. again its for my project for the "riced sleeper"
Old Dec 25, 2004 | 08:01 AM
NJcoupe's Avatar
with an ITR crank in a b16 block your going to have to have custom rods.
Old Dec 25, 2004 | 09:08 AM
jdmvtec28's Avatar
Default Re: (93ejcoupe)
A b16b is the same height as a b18 block so in theory you could use the internals of the b18c's in a b16b block and have somewhat of a sleeper... Or if you bore that same b16b block out to 84 mm and use the itr or gsr crank with their rods you would have the same 2.0l you would have if you were to use a GSR or ITR block. This only holds true of the b16b as it is a destroked b18 where as the standard b16a is the standard issue 1.6l
Just my .02
Old Dec 25, 2004 | 09:13 AM
alloutmotor's Avatar
Default Re: (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">A b16b is the same height as a b18 block so in theory you could use the internals of the b18c's in a b16b block and have somewhat of a sleeper... Or if you bore that same b16b block out to 84 mm and use the itr or gsr crank with their rods you would have the same 2.0l you would have if you were to use a GSR or ITR block. This only holds true of the b16b as it is a destroked b18 where as the standard b16a is the standard issue 1.6l
Just my .02</TD></TR></TABLE>
yes, the b16a has a shorter deck height, therefore you will need shorter rods than the itr to make it possible, or else your pistons will be above the deck height
you could use b17 crank and rods, and attempt to get close to 2.0l
Old Dec 25, 2004 | 09:49 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejcoupe &raquo;</TD></TR><TR><TD CLASS="quote">with an ITR crank in a b16 block your going to have to have custom rods.</TD></TR></TABLE>
Old Dec 25, 2004 | 11:34 AM
Pondus's Avatar
Default Re: b16 sleeved 85mm bore + type r crank and rods = high reving 2L engine? (KockAsian)
All you would need for this to work is a set of custom pistons like the ones on offer from Tech43Racing, I believe they have a compression height of 0.851". Oh and you will need to rebush the small end of yor rods too, but that's all. He designed it for LS crank and rods but ITR parts will also work, with slightly less cc's and CR as a result of the shorter stroke of the ITR crank. Will give you a killer sleeper setup
Good reading : https://honda-tech.com/zerothread?id=1019005
https://honda-tech.com/zerothread?id=951003
Old Dec 25, 2004 | 07:09 PM
Black R's Avatar
25 Year Member
.....does this mean you're looking for a "perfect" 1.75 r/s ratio out of a 2L block?
If so, I'm interested.....!
Old Dec 25, 2004 | 09:13 PM
so the perfect sleeper setup would be for civic type r head + civic type r tranny + civic type r block sleeved and bored to 85mm along with crank and rods of gsr/type r to make 1979cc and also r/s ratio to handle high reving 2L engine?
Old Dec 26, 2004 | 12:10 AM
Slow_Em1's Avatar
Default Re: (KockAsian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KockAsian &raquo;</TD></TR><TR><TD CLASS="quote">so the perfect sleeper setup would be for civic type r head + civic type r tranny + civic type r block sleeved and bored to 85mm along with crank and rods of gsr/type r to make 1979cc and also r/s ratio to handle high reving 2L engine?</TD></TR></TABLE> NO. once you change that crank out, the r/s ratio will change. the higher the mm on the crankshaft, the worse it gets. the smaller it gets, the higher you can go with it. just because it says b16 on the block, and has a crank that measures at 92mm doesnt mean it can still rev to 10k "safely"(and i quote) if you replace the ctr crank with a gs-r/type-r/LS crank, it will magically change to a lower number.
Old Dec 26, 2004 | 08:45 AM
Default Re: (Slow_Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote"> NO. once you change that crank out, the r/s ratio will change. the higher the mm on the crankshaft, the worse it gets. the smaller it gets, the higher you can go with it. just because it says b16 on the block, and has a crank that measures at 92mm doesnt mean it can still rev to 10k "safely"(and i quote) if you replace the ctr crank with a gs-r/type-r/LS crank, it will magically change to a lower number. </TD></TR></TABLE>
but a type r/gsr crank is 87.20mm, not 89. so along with the same type r/gsr r/s ratio with a larger bore, it should turn out to be a high revving b20. right?
Old Dec 26, 2004 | 09:09 AM
yeah, using the b16b with gsr crank and rods bored to 85, is basically a ITR motor bored over,
the only advantage is telling people that you have a 1.6
like i said if you guys are so worried about R/S ratio which really isnt that serious of matter even though it counts and want to fool people into thinking you have a 1.6
use b17 crank and rods in a b16a and bore it over to 85mm, the displacement should be 1.9XX
one of the most important part of having an engine MAKE power at high rpms is having a head with the right cams that flow at the RPMS that you need to make the power
Old Dec 26, 2004 | 12:19 PM
Slow_Em1's Avatar
but a type r/gsr crank is 87.20mm, not 89. so along with the same type r/gsr r/s ratio with a larger bore, it should turn out to be a high revving b20. right?</TD></TR></TABLE>
Old Apr 1, 2012 | 06:49 PM
rimsry89's Avatar
All senior user of Vtec.
I want make a setup for my engine.
spec:
-b16a block (sleeved 85mm)
-forged 85mm piston (high comp)
-head b16b (c/w b16b cam shaft,valve spring,retainer-type R)
-b20b stroke (crank shaft b20b/z)
-intake manifold Edelbrock
-mugen air cleaner
-s90 74mm throttle body
-gear box b18c type R (s80, 4.75 final drive)
-ORC (Ogura Racing Clutch-Twin plate)
*ATS-full carbon fiber clutch
*OS Giken-Twin plate
(please advise)
-ECU management (Hondata s300)
if anybody have this spec on Honda's car, can explain to me how it work and what risk on this spec?
thanks to all the old Consumers honda.
hope all your help and cooperation of all is greatly appreciated.
I'm very grateful if any that would like to share the use of the goods engines.
I Iskandar from Malaysia, very happy if can accept the guidance of all.
motorsports victories for all.
Thank You.
Old Apr 1, 2012 | 06:54 PM
[Ennis_D]'s Avatar
Holy thread revive
vtec8200
11
Jun 13, 2011 10:04 AM
weiRtech
Aug 24, 2006 11:00 AM
blkturborex
Mar 19, 2005 09:10 PM
2.2
Jun 29, 2001 01:28 AM
