auto trans help again.
Old Dec 23, 2004 | 03:22 PM
FMIDRC Racer's Avatar
Default auto trans help again.
pleae4e read this first: https://honda-tech.com/zerothread?id=1085426
ok i'm now on the 2nd trans and t.c.. i put this trans in with honda atf right from the start. drove about 5 miles just fine then started to slip again. i limped it back to my shop. today i flushed the trans cooler and it's unclogged. drove it again and after aminute it started to slip again. anyone have any idea why it continues to slip? this is killing me. i was planning on useing this money to by my family x-mas presents but it's looking like it's not gonna happen. please someone help me!!!!!!!
Old Dec 24, 2004 | 12:24 PM
well i just went back to my work to work on the car in the parking lot. it seems as if though it threw a code this time. it threw code 5. i looked it up and it appears to be a console shift switch. i guess that i wil have to try and replace or adjust this frst huh? i don't know how it could be bad. the dash shows that it's in the proper gear.
Old Dec 27, 2004 | 04:29 PM
spooned out's Avatar
Default Re: auto trans help again. (FMIDRC Racer)
if its throwing a code..its throwing it 4 a reason...yeah put a new switch on and go from there..dependin on year...it maybe ur tranny gear box...its like an ecu fro ur tranny
Old Dec 27, 2004 | 06:23 PM
Default Re: auto trans help again. (spooned out)
fixed the reason why the code was popping up and it's still slipping. this is starting to freak me out. i'm really getting pissed off now at this car.
Old Dec 27, 2004 | 06:26 PM
CDEEE5's Avatar
bad TCU?
Old Dec 27, 2004 | 08:10 PM
Default Re: (CDEEE5)
i can detec codes and doesn't have a steady red light on. last thing that i can think of elec wise is that the battery is pretty dead. i have been jump starting it everytime. so i'm gonna try and replace the battery and see if that helps. i'm thinking that maybe there isn't enough juice to open/close the shift solinoids.
after taking it for a short test drive tonight i ended up with the car not moving at all in drive. so after puching the car for a few hundred feet trying to get back to the shop i decided to give reverse a try. it went into reverse no problem and i drove in reverse the whole way back to the shop. this is starting to get old real quick.
Old Dec 28, 2004 | 04:04 AM
Vanilla Sky's Avatar
sounds to me like you got a bad transmission... i had the same symptoms and when i replaced the trans with a known working part, it was good again...
you may want to consider putting in a decent sized transmission fluid cooler... i got one off on a ford aerostar van at the junkyard, and it keeps my transmission very cool... it's a good idea to put a bigger-than-stock transmission cooler on these cars...
hope my 2 cents helps any...
Old Dec 28, 2004 | 06:15 AM
SpeedFreak77's Avatar
Could the torque converter be bad?? Just a suggestion don't know much about automatic's.
Old Dec 28, 2004 | 04:38 PM
Default Re: auto trans help again. (SpeedFreak77)
thank s again for the relies. the car has also gotten a different converter with each trans. and it works fine for a few min but then just goes all to ****. i tried today with a better battery and it's still fucked. i'm gonna give the shop a call and tell them that i want my money back.
Old Dec 29, 2004 | 06:01 AM
do that... you have a bad transmission, man...
Old Dec 29, 2004 | 02:40 PM
Default Re: (Vanilla Sky)
well asking for my money back didn't go as planned. he's sending me yet another trans that he gaurantee's is good. this **** is starting to get old though. if this next one doesn't work i'm gonna go down there and ring his neck.
Old Dec 29, 2004 | 03:52 PM
Mike813's Avatar
Default Re: (FMIDRC Racer)
dont forget to put everything on paper & have it signed... incase he tries bending you over again.
Old Dec 29, 2004 | 04:05 PM
Default Re: (Mike813)
he is close enough that i could drive over and beat his ***. keep in mind here though that each tranny that i have gotten after the first hasn't cost me a dime. he is being very good about this and hasn't even asked for the old ones back. he's not even charging me shipping. if i can get this all resolved ok i would recommend this shop to anyone. so far i've just been losing allot of labor.
Old Feb 2, 2005 | 05:32 PM
well here's the update. i just got to drive the car after finishing putting another trans in again. this is the 3rd one. this trans was spamed "F20" instead of f22 like the rest. i haven't had the time to mess with the car plus it took him a while to send the trans.
so anyways i just got driving it for a long time and it seems to be good. i have the trans cooler bypassed till i can flush it again. but now i'm getting a trans code #12. one long flash then 2 short. anyone know what this is? i'm throwing a CEL as well cause i broke the engine temp sensor while putting in the trans. anyone know what code 12 is? "S" light is flashing.
1yesfan
Mar 12, 2015 02:31 PM
rbpwrd240
Jun 7, 2012 04:51 PM
ej1project
Honda Civic (2001 - 2005)
Sep 7, 2010 08:26 PM
not-a-stang
Apr 17, 2008 04:47 PM
