taking off my b16 head help
under the cams. you should be able to see 10 bolt heads that are 12pt. 13mm maybe. remove these and presto. remember the dowel pins may make it a little hard.
Modified by ohboy95c at 10:20 AM 12/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">you'll need to remove the cam caps and cams, yes.
And use a 6 pt 14 to remove the head bolts.</TD></TR></TABLE>
thanks man
thanks man
Firestarter
Nov 5, 2005 01:30 PM
