Have some questions about boosting D16A9-ZC
I have a D16A9 engine, better known as DOHC ZC - 130PS.
Stock CR is about 9.5:1... running on 14psi, what would be the right CR? I have an option to put in pistons from D16A7 (not sure if they are the same height) - CR would be 8:1.
Whole engine will be rebuild. Where is the limit, using stock pistons and rods? Would 14psi be too much? OK, who has done that and what were the consequences? I know what can happen... but where is the limit...
Stock max rev is set to about 8000 rpm. How to choose a right turbocharger?
From where to get oil for turbine lubrication? I mean, from oil pump->turbine->oil pan? Any picture to show me how to work that out?
Who is Mr Robot?
tee of from the back of the block where the oil pressure sensor is, then it goesto the turbo then oil pan
PINKS
Jul 28, 2006 04:51 AM
sweet
Apr 24, 2003 10:29 AM
