Ignition timing question...
Old Dec 22, 2004 | 09:17 AM
emotionisdead's Avatar
Very Emergency!!
Default Ignition timing question...
hey guys what is your ignition timing set at on the dizzy? you know where the advance is when using a timing light. i am trying different timing settings and would greatly appreciated your guys input. i am going to try mine a 16 degrees.
Old Dec 23, 2004 | 05:01 AM
civic-4-ges's Avatar
Default Re: Ignition timing question... (Booyakasha)
16 degrees here!
I am curious how that helps you though
Old Dec 23, 2004 | 06:21 AM
iv's Avatar
iv
Depending on your motor 16 could be the stock setting if you want to get a little more out of it you can set it to 18 but I wouldnt go over that
Old Dec 23, 2004 | 03:52 PM
DIFFUT'S INC.'s Avatar
Default Re: (iv)
i saw a post with a B18c5 dyno with timing 16 and turn it up to 18 and gain a about 5 hp but that was a post so........
bonylad
Jun 14, 2006 09:19 AM
Boosted Chemist
Aug 20, 2005 07:25 AM
Jerry
Jan 27, 2003 05:42 PM
Keane Rated R
May 13, 2002 09:37 PM
