Experiences Wanted: getting 86mm bore to seal.
Old Dec 21, 2004 | 06:04 PM
asubennett's Avatar
Default Experiences Wanted: getting 86mm bore to seal.
Hi guys, I don't want theory and here say.
If you have not run an 86mm bore or know someone that has run an 86mm bore please do not respond.
For those of you that have, any proplems with it. How often did you go through gaskets.
Any tips to aid in getting it to seal? Thanks in advance for the help you may provide.
Old Dec 21, 2004 | 07:05 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Experiences Wanted: getting 86mm bore to seal. (asubennett)
hey this is mike k. using my friend's screen name. anyway, my best friend in florida did it, and the motor lasted for like 15 minutes before he blew a headgasket... then he had the block o-ringed and we used a copper headgasket.. it lasted for a week. no matter what, it kept blowing headgaskets. if you want to talk to him more, he is on this board. his name is topspeed86.
Old Dec 21, 2004 | 07:19 PM
CSRacing's Avatar
I ran a 86mm bore, and bigger, had no problems with it at all, yes it was a race car, not a street car, but still we run lots of compression, and still have no problems with it, but on a street car, Im not sure how dependable this would be, but no need to oring the block, we run cosmetic head gaskets, with the fire ring, no problems at all.. I would definitley recommend a quality sleeve, if your going to be running that large of a bore.....
Old Dec 21, 2004 | 07:39 PM
b19coupe's Avatar
Running 14.1+ compression on an 86mm bore. Cometic head gasket and copper spray blew the first pass on the dyno. OEM gasket bored to 86mm and Indian head gasket sealer and no problems. 15+ dyno passes and 18 runs down the 1320.
Old Dec 21, 2004 | 08:16 PM
C-NYCE's Avatar
we used a oem gasket bored 86mm with copper spray and never it held up then we used block seal from any auto store and never had a problem there after we drove the car from n.y. to n.j. 130miles and raced
Old Dec 21, 2004 | 09:22 PM
asubennett's Avatar
Default Re: Experiences Wanted: getting 86mm bore to seal. (C-NYCE)
Thanks for the responses guys.
If I may ask what is Indian head gasket sealer? Also what is block seal?
Old Dec 21, 2004 | 09:36 PM
rodimus's Avatar
hie yaa yaa yaa
hie yaa yaa yaa
Old Dec 21, 2004 | 09:37 PM
b19coupe's Avatar
http://www.permatex.com/produc...20539
I don't know why, but it works.
Old Dec 22, 2004 | 07:58 AM
Jeremyinlinepro's Avatar
We have been running 86mm bore street cars for a couple of years now that probably have 20-30k miles on them. I haven't had one have any problems with their headgaskets. In fact I just finished two street car motors with 86mm bore x 95mm cranks that are out driving around now. As long as the motor is assembled properly you won't have any problems with the headgaskets. I don't use any kind of sealant just the gasket. Alot of issues with headgaskets have to do with tuning not the bore size. If you have any more questions about it let me know
Old Dec 22, 2004 | 08:22 AM
asubennett's Avatar
Default Re: Experiences Wanted: getting 86mm bore to seal. (Jeremyinlinepro)
That is good to know. Any tricks or assembly points I should pay extra close attention to. Were the these blocks step decked or o-ringed at all?
Old Dec 23, 2004 | 12:03 PM
asubennett's Avatar
up again for more insight.
Old Dec 23, 2004 | 12:27 PM
rodimus's Avatar
go 85.5 and have a little more piece of mind? *shrugs*
Old Dec 23, 2004 | 07:47 PM
Ek00fbp's Avatar
If you could go into more detail about what to check or be aware of when assembling it would be appreciated. I only ask because many people have had issues, and many have been fine. So naturally im wondering beyond assembly what are people not doing properly.
Old Dec 23, 2004 | 09:50 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Experiences Wanted: getting 86mm bore to seal. (Ek00fbp)
I would think having the deck and head as close to perfectly flat as possible would be vitally important here.
Old Dec 23, 2004 | 10:26 PM
asubennett's Avatar
Default Re: Experiences Wanted: getting 86mm bore to seal. (rochesterricer)
From what I have gathered so far it seems that a perfect tune is most important. Any kind of detonation is going to make the gasket give.
Old Dec 23, 2004 | 10:30 PM
MikeSarr_GSR's Avatar
I forget what this is called, I know some guys do this. When the deck is like .005" lower than the top of the sleeves... I forget this procedure. Is this something that helps with sealing the HG?
Old Dec 23, 2004 | 10:32 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">I would think having the deck and head as close to perfectly flat as possible would be vitally important here.</TD></TR></TABLE>
Yes I would say so.We run 87 and don't have a problem .and we use stock gaskets ,just cut out with a boring bar
And the block ,sleeve thing is called letting the sleeves hang out about .005 or so.lol
Old Dec 23, 2004 | 10:34 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Experiences Wanted: getting 86mm bore to seal. (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">I forget what this is called, I know some guys do this. When the deck is like .005" lower than the top of the sleeves... I forget this procedure. Is this something that helps with sealing the HG?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Were the these blocks step decked or o-ringed at all?</TD></TR></TABLE>
Old Dec 24, 2004 | 09:38 AM
asubennett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">
Yes I would say so.We run 87 and don't have a problem .and we use stock gaskets ,just cut out with a boring bar</TD></TR></TABLE>
Holy Moly- What am I worrying about then. J/K
Randy, what sleeves are you using on these 87mm bore cars. If you are being sarcastic and are talking about an H22 then shame on you.
civic-r11
Jun 25, 2011 03:16 PM
bOoStEd_180e
Jun 19, 2011 06:06 PM
Pandahatch
Feb 5, 2007 09:39 PM
Rescued R
Dec 15, 2004 09:34 PM
93B17A
Jan 28, 2002 08:42 PM
