Lsvtec ecu and harness
Hey soon I will have an 1998 itr shell or 1998 rs, but im really confused with putitng all thease OBDI together, first what vtec ecu will I use?Any?What OBDI will I need for dizzy?Will I need a OBDII to OBDI adapter harness ?
to make it easy I would get a 98-ls or gsr or R engine harness. cause it is OBD2 and will match a OBD2 motor and chassis harness. then get a OBD2 to OBD1 jumper and then get a obd 1 ecu. if you go hondata just use a P28 since you are going lsvtec. you could also use the hondata P28 that they sell so need for a jumper. it has the OBD2 plugs on it.
jdmshawn95
Jan 14, 2011 11:12 AM
