DA integra brakes onto civic problem, they're sticking
Old Dec 21, 2004 | 09:55 AM
89dxhunchback's Avatar
Default DA integra brakes onto civic problem, they're sticking
Well, I made a thread in the CRX/EF civic section, but since this is also a general car question, and there is a broader band of people "in the know" in this section, I thought I'd make a thread here too.
I swapped all the disk brakes from a DA integra on to my 89 civic and everything was pretty smooth. I also installed SS brake lines. I haven't installed the "4040" proportioning valve yet.
I can drive the car, but I can feel the brakes staying on. When I get out, I can smell them. I tried opening the bleeder valves and screwing the rear caliper piston into the caliper, but it only helped for about 1/2 a day.
It got sooo bad yesturday that I blew a head gasket on the interstate trying to over come the brakes !! The HG is no problem, but I do need to know how to fix my brakes....
Here's a copy of the other thread if your interested https://honda-tech.com/zerothread?id=1088795
Old Dec 21, 2004 | 10:20 PM
88redrex's Avatar
Default Re: DA integra brakes onto civic problem, they're sticking (89dxhunchback)
New calipers? If they are stock of the DA they could be frozen
Old Dec 22, 2004 | 04:48 AM
dwnthehatch's Avatar
Are the front or rear brakes sticking? You might want to check you ebrake cable to see if it's too tight.
Old Dec 28, 2004 | 10:53 AM
Default Re: DA integra brakes onto civic problem, they're sticking (dwnthehatch)
the front are sticking too. There's no way the rear brakes have enough strength to stop a 200hp civic against its will. Plus the fronts smoke too, hehe.
Tooooslow
Suspension & Brakes
Apr 5, 2017 12:18 PM
Mr.Cheezil
Jul 4, 2012 10:24 PM
pootie.teng
22
Jul 12, 2006 07:27 PM
sleeping beauty
Apr 7, 2004 05:13 PM
