i blew my 00b16 block, tryin to find a way to clean new block
Old Dec 19, 2004 | 04:53 PM
honhatchisbak's Avatar
Default i blew my 00b16 block, tryin to find a way to clean new block
i just picked up a b16c1 short block from a friend of mine, and inside the combustion camber theres a lil rust in there from it sittin for a while, he said i can clean it with with some carburator cleaner and wipe it carefully, then its some automatic trans fluid put a lil in each camber and rotate the crank, till it cranks freely, just wondering if anyone has done this without gettin the actually block honed out, is there any other way of cleaning it out, thanks
Old Dec 19, 2004 | 05:06 PM
Unsivil_audio's Avatar
Yes. You shouldnt have any problem.
Old Dec 21, 2004 | 02:51 PM
wshondaman's Avatar
Default Re: i blew my 00b16 block, tryin to find a way to clean new block (honhatchisbak)
as far as i know you can go to the local hardware/ parts store and buy a cylinder honing tool that will attach to the end of a drill. and it should cost about the same as that quart of trans fluid. if you don't have any luck with that your first idea should work i'd add a bit of sandpaper very fine grit to remove the rust before turning the engine over.
Old Dec 21, 2004 | 03:01 PM
BoostedEG6's Avatar
Default Re: i blew my 00b16 block, tryin to find a way to clean new block (wshondaman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wshondaman &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know you can go to the local hardware/ parts store and buy a cylinder honing tool that will attach to the end of a drill. and it should cost about the same as that quart of trans fluid. if you don't have any luck with that your first idea should work i'd add a bit of sandpaper very fine grit to remove the rust before turning the engine over. </TD></TR></TABLE>
yeah I wouldnt use either one of those meathods (sp?) because if you use sand paper you take awau the etching of the stock hone and with the hone thing thats just going to make the hone bigger than what it already is and the rings are not going to seal like before.... my best advice is to spray it with the carb cleaner and use the trans fluid untill it spins freely
Old Dec 22, 2004 | 06:13 AM
Default Re: i blew my 00b16 block, tryin to find a way to clean new block (BoostedEG6)
thats what i did and its fine now
jdm_SirG
Aug 27, 2006 06:46 PM
LUXXXX
Aug 16, 2006 08:16 PM
B18EG6
Jul 28, 2004 01:33 PM
int3gra
Mar 2, 2004 10:02 PM
senpai
Jul 25, 2003 12:10 PM
