stripped strut hex key hole thing
Old Dec 19, 2004 | 03:47 PM
komat's Avatar
Default stripped strut hex key hole thing
i just notice the top of hte strut where you use a hex key to lock it into place and use a wrench to turn the nut was strip( the hex hole is stripped). Is there any other way getting that off without buying a new strut
Old Dec 19, 2004 | 03:50 PM
Sliced Beard's Avatar
Default Re: stripped strut hex key hole thing (komat)
a good impact wrench and stand on the spring in get the fug out of dodge
Old Dec 19, 2004 | 03:55 PM
komat's Avatar
Default Re: stripped strut hex key hole thing (DirtySol)
only problem is if i remove it the lca bolt will break or at least i think it will so either way i will have to get a new strut unless you can do it without standing on it?
Old Dec 20, 2004 | 03:15 PM
komat's Avatar
i trie dusing hte impact wrench tonight but it didnt work. all it did was just spun the rod. is there a special way to do it?
Old Dec 20, 2004 | 03:16 PM
civictildeath's Avatar
Default Re: (komat)
if you got new shocks put vise grips on the shaft and then turn it
Old Dec 20, 2004 | 03:28 PM
komat's Avatar
Default Re: (civictildeath)
i got some coming in the mail may have to do that
Old Dec 20, 2004 | 03:29 PM
Default Re: (komat)
i had to do that on one of mine. try to make a flat spot on it cause it will make it a lot easier
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">if you got new shocks put vise grips on the shaft and then turn it</TD></TR></TABLE>
correct. especially if your geting new ones. Also if you have lowering springs or coilovers, then you wont have to worry about the spring shoting at you.
Old Dec 20, 2004 | 03:30 PM
_Spugen_'s Avatar
OWNED.....H-T member Dimi did the same daim thing...
Old Dec 20, 2004 | 03:38 PM
90 Si Hatch's Avatar
Default Re: (SpugenEG)
i had the same problem one time. so i got out my vicegrips and griped the shaft that goes up and down inside the strut and then i just broke it loose with my end rench. BUT this will only work if you dont have your dust caps on!!!
Old Dec 20, 2004 | 03:56 PM
komat's Avatar
is there a way to save the the strut without destorying it? also is it possible to loosen the nut while the strut is still bolted in the car loosen the bolt in the hatch/trunk
Old Dec 20, 2004 | 04:26 PM
Default Re: (komat)
YES!!!!, WHAT I SAID. IT WILL NOT MESS ANYTHING UP!!!
Old Dec 20, 2004 | 04:32 PM
mulletov's Avatar
I ran into that problem a couple weeks ago. U should take the whole strut assembly off. Take the vise grips and wrap rubber bands around the teeth so u don't scrape the shaft too much. U could probably wrap them around the strut if u want. Then clamp them on that strut shaft hard as u can. Stand on the vise and strut and try to break loose the top nut. Oh, u can just cut the dust cover to get at the shaft. And I think it would be a lot harder if the strut is still on the car, so might as well take it off.
Old Dec 20, 2004 | 04:48 PM
komat's Avatar
Default Re: (mulletov)
i would take it off but if hte lca bolt breaks i be fucked....
Old Dec 20, 2004 | 04:53 PM
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">i would take it off but if hte lca bolt breaks i be fucked....</TD></TR></TABLE>
No your not. Those are cheap metals, just get a spare bolt just in case. Also if you want you can take it to like a mechnic, and they can spin it off for you.
Old Dec 20, 2004 | 05:18 PM
komat's Avatar
Default Re: (sohcvtec1995)
if the bolt of the head breaks off how you get it off?
spens 91 Ef
Oct 8, 2008 05:44 AM
4drsedaneg
Suspension & Brakes
Feb 25, 2005 10:01 AM
EK k kay
14
Aug 20, 2004 10:28 AM
streetspeed607
May 3, 2004 05:11 AM
Nocturnal
Nov 26, 2003 04:03 PM
