Check engine light came on while driving?
get a diagnostics done, its like 60$... but before you do that, make sure your gas cap is tight (believe it or not in some cases its the cause), then reset your ecu (disconnect battery for a few minutes) and see if light comes back on. If it comes back on, try to do the "jumper" trick. I dont know much about your model accord, 91 I'm assuming? But do a search and do your own diagnostic. If you cant figure it out, pay someone to test it. Good luck.
Guest
Posts: n/a
93gsrhatchbrid
11
Mar 31, 2006 03:26 PM
