93 hatch just died?
Old Dec 18, 2004 | 07:29 PM
skunk2eg's Avatar
Default 93 hatch just died?
my 93 cx was just sitting there running and out of the blue it just shut off. Checked all the fuses and ground wires, battery is good, its not the starter. i'm thinking its the distributer, the motor isnt getting a spark.... when i turn it over it just sits there clicking...anything else it could be?
are the cx, dx, vx, non-vtec distributers the same if i replace it?
thanks -nick
Old Dec 18, 2004 | 07:30 PM
xCIVICx's Avatar
Default Re: 93 hatch just died? (skunk2eg)
main fuse? what temp was it running at? and what kind of click... like a relay click, or a trying to turn the car over click?
Old Dec 18, 2004 | 07:33 PM
skunk2eg's Avatar
Default Re: 93 hatch just died? (xCIVICx)
main fuse is good, running at normal temp and its the repeated trying to turn over click
Old Dec 18, 2004 | 07:35 PM
VTiVTo8000rpm's Avatar
It's the bendix in your starter *maybe*
Old Dec 18, 2004 | 07:37 PM
skunk2eg's Avatar
Default Re: 93 hatch just died? (VTiVTo8000rpm)
im thinkin it isnt the starter cause it was running, THEN it died
Old Dec 18, 2004 | 08:17 PM
sidoe's Avatar
I think it is distributor related. Either the igniter or the coil.
Old Dec 18, 2004 | 08:18 PM
KayOs's Avatar
Default Re: 93 hatch just died? (sidoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidoe &raquo;</TD></TR><TR><TD CLASS="quote">I think it is distributor related. Either the igniter or the coil.</TD></TR></TABLE>
Coil most likely went bad. Test to see if you are getting spark to any of the spark plug cables.
Old Dec 18, 2004 | 08:20 PM
skunk2eg's Avatar
Default Re: 93 hatch just died? (KayOs)
no spark to any of the wires
Old Dec 18, 2004 | 11:41 PM
Do_Ster's Avatar
to answer one of your questions, the cx and dx dizzy's are the same. the vx dizzy is the same as a z6, vtec-e yO!
Old Dec 19, 2004 | 12:59 AM
E-brake or Handbrake's Avatar
Default Re: (ntogethernow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">no spark to any of the wires</TD></TR></TABLE>
That's your prob. Check dizzy.
Old Dec 19, 2004 | 11:28 AM
suckawillis's Avatar
Default Re: (Inconclusive)
dizzy
Old Dec 19, 2004 | 09:55 PM
frank16's Avatar
check your coil and the (+Positive wire) that connects to it. It happen to me in my gs.
Old Dec 19, 2004 | 10:51 PM
Tad's Avatar
Tad
Default Re: 93 hatch just died? (frank16)
if it just sits there clicking, that sounds like the starter isnt even trying to work at all.
just a thought,
cuz even if your dizzy is toast, it should at least try to crank.
Old Dec 19, 2004 | 10:57 PM
c for sea's Avatar
my vote goes for coil or just replace the whole dizzy to be sure.
Old Dec 20, 2004 | 07:57 AM
skunk2eg's Avatar
Default Re: (c for sea)
if it was the starter then why would it just die while it was running?
Old Dec 20, 2004 | 08:09 AM
HatchEh2's Avatar
Default Re: (skunk2eg)
well you DIDN'T hydro lock, but if the starter is just clicking, makes it sound like u did...
anyway,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c for sea &raquo;</TD></TR><TR><TD CLASS="quote">my vote goes for coil or just replace the whole dizzy to be sure.</TD></TR></TABLE>
but the starter...could be hooked up wrong is my guess... something went wrong with it...but yea it didnt cause the car to stall in the begining... hmm check the connections on it. when i bench tested a starter at school i remember one were the thingy didnt poke out of the starter to grab the flywheel, that could have went on ya... just my 2 cents
Old Dec 20, 2004 | 01:19 PM
skunk2eg's Avatar
Default Re: (HatchEh2)
just fixed it, it was the coil...thanks to all that replied
Old Dec 20, 2004 | 01:37 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">just fixed it, it was the coil...thanks to all that replied</TD></TR></TABLE>
sweet, congrats,
and good to know what the prob was.
oXeNo
Aug 9, 2011 08:37 PM
13BT
Aug 5, 2004 08:14 PM
Therapy
20
Jun 30, 2004 08:45 AM
00fbp
Jul 28, 2003 07:06 PM
zzzkenji
10
Apr 24, 2003 07:17 AM
