1500 rpm horrible sound.
Old Dec 17, 2004 | 02:56 PM
dailydriven's Avatar
Default 1500 rpm horrible sound.
Ok. I searched and only found one post about this problem and wasn't that helpful. No matter if the car is cold/hot idling/moving it makes this loud vibrating sound. I tried to hear where it is coming from and it sounds like it is coming right after the cat. convertor. If anyone has had this problem and knows a fix, please help it would be greatly appreciated. Thanks. (1993 Civic Si)
Old Dec 17, 2004 | 03:02 PM
DAguyLS's Avatar
it's either an exhaust hanger that broke, or it's one of the bolts that hold your exhaust together is loose, or and this is what it probably is.....your cat.
Go under your car and give your cat a nice bang on the bottom, if you hear **** inside ratteling around then you need to get yourself a new converter.
Old Dec 17, 2004 | 03:12 PM
99hatch's Avatar
Default Re: (slamdLScivic)
heat shield
Old Dec 17, 2004 | 03:28 PM
Giga Crusher's Avatar
Default Re: 1500 rpm horrible sound. (cookiEG)
Its the heat shield, i had the same problem before, and there are actually three of them, one is right after the cat, the other two is on the rear right wheel. try to remove all of them. its annoying especially when you back up the car.
Old Dec 17, 2004 | 06:17 PM
hcivic99's Avatar
Default Re: 1500 rpm horrible sound. (Giga Crusher)
its the heat shild
jugodmyko
13
Sep 21, 2007 05:23 AM
89efDUSTY
Mar 9, 2007 08:48 AM
puertoroc7976
Jul 18, 2006 07:32 AM
01BlackAc
Sep 13, 2004 07:31 PM
kamdog
Mar 25, 2003 10:11 AM
