Misfire Code for Cyl's 1 and 4...but car funs perfect?
Referring to this thread
https://honda-tech.com/zerothread?id=1088038
Went to Autozone, got the codes read. P301, P304, and P300.
Cylinder 1 misfire, Cylinder 4 misfire, random/cylinder misfire. HOWEVER, the car runs perfect. Like I stated in the earlier thread, CEL comes on when it's being started and it's cold outside. Plugs are new, wires are relatively new, and I will check the distributor cap.
What's causing this code, yet no loss in performance or a misfire? The car runs like a champ.
Modified by ****** at 4:34 PM 12/17/2004
Have you done a compression test? When you change the dist. cap might as well change the rotor, and fuel filter.
Also have your injectors tested, they may be clogged/dirty.
Compression's good, fuel filter is less than 10,000 miles old, spark plugs brand new, injectors are good, I checked the distributor cap. I haven't changed the dist. yet, but it's a little dirty inside, not too bad.
Is there some connection between the engine being cold since the weather's so cold, and the dist misfiring? Maybe just because it's getting old? I plan on changing the dist cap and rotor when I have the $$, just wondering in the meantime. The car runs fine before and after the CEL comes on. Like I said, it comes on within 10 secs. of the car being started. TIA.
purple98ek
Mar 19, 2006 07:04 PM
