poor mans type r
Old Dec 17, 2004 | 03:44 AM
turbob16's Avatar
* B A N N E D *
Default poor mans type r
Here's my question and concern......
I dropped my B18C1 block off at the maching shop and when i went to pick it up it had some damage on the deck, how it got there I dont know and either do they (SURE), anyways it looks like to get the damage off its going to take about 18thous. off the top to clean it up. Now my concern is, im going to take 18 off the deck and I already took 8 off of the head to clean that up, im going to be running ctr .25 over pistons. So what i have is a gsr bottom end with b16a head ported running stock valves, that might be important also to factor in. I'm worried about piston to valve clearance with a stock head gasket, also if im going to be able to run bigger cams then i already have which are ctr cams. Now i know i could just throw a thicker head gasket on it and call it a day but i want to know if i would be safe to throw this together with a stock head gasket and run buddy club spec III. Also helf me out on what the compression would be along with the clearance that im going to have. thanks any help is greatly appreciated.
Old Dec 17, 2004 | 03:15 PM
LSVTEC 91 Civic's Avatar
Banned
Best bet would probably be to clay the engine.
Old Dec 17, 2004 | 03:42 PM
JoeB18R's Avatar
Default Re: poor mans type r (turbob16)
or you could buy my stock B16A2 bare block for 250 bucks and build the ****** up!
Old Dec 17, 2004 | 06:28 PM
turbob16's Avatar
* B A N N E D *
you guys are killing me here (i already have 2 b16a bare blocks). what is the closest valve to piston clearance you guys have run with big cams. example .030,.025,.020
Old Dec 18, 2004 | 08:55 AM
99 TYPE R's Avatar
joe b18 r how much is a shortblock b16 worth then with 63k on ran perfect when swapped out, oil pan and all
Old Dec 18, 2004 | 10:00 AM
cedete's Avatar
Default Re: (99 TYPE R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 TYPE R &raquo;</TD></TR><TR><TD CLASS="quote">joe b18 r how much is a shortblock b16 worth then with 63k on ran perfect when swapped out, oil pan and all</TD></TR></TABLE>
thread jacked y0!
Old Dec 22, 2004 | 01:59 AM
JoeB18R's Avatar
Huh? Want to reword that? re you asking how much YOURS would be worth w/ 63k on it?
Really I wouldnt sell a bare block for more then 250. With perfectly working internals, and 63K on it, maybe 350 tops.
Old Dec 23, 2004 | 10:42 AM
turbob16's Avatar
* B A N N E D *
thanks for jacking my thread............................
Old Dec 23, 2004 | 05:07 PM
JoeB18R's Avatar
Default Re: (turbob16)
youre welcome.
Old Dec 25, 2004 | 12:41 PM
EG617's Avatar
My setup is close to yours i got a jdm b18c stock piston with a b16 head milled 35-40 thousandth with buddy club with a stock head gasket and my clearance is fine.
Old Mar 21, 2005 | 01:46 AM
mrtoker13's Avatar
b16a head on gsr block
juba_x
14
Jan 8, 2012 01:42 AM
brookliner7
Aug 30, 2005 05:27 PM
McFly
Jun 18, 2004 06:16 AM
Johnny Knoxville
Jun 28, 2003 02:53 PM
jdmhondageek
Feb 26, 2002 10:55 AM
