Cost of bottom end rebuild?
Old Dec 16, 2004 | 11:30 PM
Hatchbizzack's Avatar
Default Cost of bottom end rebuild?
In the next week or two, I may end up purchasing a 5th gen Prelude off a close friend of mine. Although the engine hasn't been extremely beat on by him, the engine does have more than 135k miles and I plan to do be doing some heavy modding to it.
I was wondering, how much on average would it cost me to rebuild the bottom end? New bearings, piston rings, gaskets, seals and everything else needed. I considered using forged pistons and rods, but I have been told the h22 has to be sleeved for forged piston use so I may end up going with Type S pistons since the install of cams will be inevitable.
Thanks.
Old Dec 16, 2004 | 11:36 PM
H22Power_521's Avatar
resleeving is around 1k alone if you decide to do that. if you want a completely built block with new sleeves, pistons, rods, all machine work, etc it'll be around 3k depending on who does the work.
Old Dec 17, 2004 | 06:55 AM
Default Re: (H22Power_521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Power_521 &raquo;</TD></TR><TR><TD CLASS="quote">resleeving is around 1k alone if you decide to do that. if you want a completely built block with new sleeves, pistons, rods, all machine work, etc it'll be around 3k depending on who does the work.</TD></TR></TABLE>
.....I just meant an OEM rebuild
Old Dec 17, 2004 | 06:27 PM
PrettyLude's Avatar
since you are already spending that much, oem parts are not cheap, go aftermarket
Old Dec 17, 2004 | 07:25 PM
PreludeSiTdriver's Avatar
Default Re: Cost of bottom end rebuild? (Hatchbizzack)
hey man i got a gully built h22a and the guy is awesome and he is good on his prices
Old Dec 18, 2004 | 08:41 AM
Default Re: Cost of bottom end rebuild? (PreludeSiTdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeSiTdriver &raquo;</TD></TR><TR><TD CLASS="quote">hey man i got a gully built h22a and the guy is awesome and he is good on his prices</TD></TR></TABLE>
....what was that supposed to mean? I suppose you meant fully built, but at first it's yours and then the guy has good prices and is awesome? I am confused
My stepdad is a mechanic, so I get all the parts at 15% discount of dealer price, I don't really want to build my current block because there will be too much downtime and buying another block is more money to spend.
Old Dec 18, 2004 | 10:53 AM
RavynX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">....what was that supposed to mean? I suppose you meant fully built, but at first it's yours and then the guy has good prices and is awesome? I am confused
My stepdad is a mechanic, so I get all the parts at 15% discount of dealer price, I don't really want to build my current block because there will be too much downtime and buying another block is more money to spend.</TD></TR></TABLE>
I think he meant that he got a fully built h22a and the guy that did the build is awesome and has good prices. Might want to ask him who this person is.
Old Dec 21, 2004 | 08:22 PM
2.2SICKLUDE's Avatar
DAMN!!! that's cheap for a fully built bottom h22 ? I got mine for more than that... too much i think...
Old Dec 21, 2004 | 10:42 PM
SKDRCR's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">since you are already spending that much, oem parts are not cheap, go aftermarket</TD></TR></TABLE>
If he doesn't want to sleeve, then I would definately go with OEM parts.
Old Dec 22, 2004 | 02:48 PM
Boost3d22's Avatar
Default Re: (SKDRCR)
i just spent 5k on a complete rebuild for boost , head and bottom, the bottom cost me 2500, Darton sleeves , weisco pistons, eagle rods, crower crank , new oem parts
Old Dec 22, 2004 | 02:49 PM
Boost3d22's Avatar
if your going to replace the pistons you have to sleeve regardless
Old Dec 22, 2004 | 03:02 PM
Hawkze_2.3's Avatar
Default Re: (Boost3d22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost3d22 &raquo;</TD></TR><TR><TD CLASS="quote">if your going to replace the pistons you have to sleeve regardless</TD></TR></TABLE>
He said an OEM rebuild, so he does not need to sleeve. Sleeving is only needed if you run forged pistons...
Old Dec 22, 2004 | 04:11 PM
mgags7's Avatar
for an all motor build i say JUN pistons, 12.3 and frm sleeves are fine....but the bill will be about 1k for those babies.....
thats my plan anyway, cryo the crank, Crower rods, and Jun pistons....then oem bearings and full balancing.....
Old Dec 22, 2004 | 06:35 PM
BB6-213's Avatar
Earl is building mine for 3300. fully built.
Old Dec 22, 2004 | 10:47 PM
OEM_ASSASSIN's Avatar
Default Re: (BB6-213)
I have type S pistons, rings, and camshafts in my room waiting to be installed. Do I need to replace the sleeves and the rods also? I have skunk2 springs and retainers also, but I am not really sure If they are neccessary. Almost every reply on that subject conflicts with the next in the Type S cam thread .
anybody who has just type S pistons and cams installed know about how much it should cost?
edit: BTW I have a 92 JDM H22A
Old Dec 22, 2004 | 11:03 PM
PrettyLude's Avatar
type s will not require sleeves
TurboGSR96
Feb 22, 2006 05:48 PM
Crate
Dec 5, 2003 03:34 PM
MikelH
Aug 4, 2003 01:52 AM
