ls/vtec in my 91 ef - girdle or no girdle??
Old Dec 16, 2004 | 09:29 PM
awdriscol4's Avatar
Default ls/vtec in my 91 ef - girdle or no girdle??
What are everyone's opinions on girdles for ls/vtec builds? Im looking at the Golden Eagle kit, which include the girdle, gsr main bolts, windage tray and oil pickup, and its around $380. The motor is a NA ls/vtec, with ctr pistons, etc...basically a high compression NA motor.
Is the girdle worth the cost? Also, the info says "All girdles MAY require block align boring AFTER install!" What is block align boring?
Thanks
Alfred
Old Dec 16, 2004 | 09:42 PM
teamols's Avatar
Default Re: ls/vtec in my 91 ef - girdle or no girdle?? (awdriscol4)
anything that helps a main cap=good you can also try the all motor forum
Old Dec 16, 2004 | 11:10 PM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriscol4 &raquo;</TD></TR><TR><TD CLASS="quote">What are everyone's opinions on girdles for ls/vtec builds? Im looking at the Golden Eagle kit, which include the girdle, gsr main bolts, windage tray and oil pickup, and its around $380. The motor is a NA ls/vtec, with ctr pistons, etc...basically a high compression NA motor.
Thanks
Alfred</TD></TR></TABLE>
Are there any other aftermarket components in your bottom end? Basically the girdle helps to keep the engine "stable" and high RPM's. But if you don't have the parts to take advantage of it i.e. rods, I wouldn't bother.
Old Dec 16, 2004 | 11:41 PM
ServiceAdvisor's Avatar
Better safe then sorry. Why put so much money into an engine combination that has time and time again shown to be somewhat unstable when rev'd out and not take the necessary precautions to keep your investment alive. IMO Get the girdle. - Darrell
hondaguyexsi
Oct 12, 2005 05:19 PM
limpy
Jul 14, 2005 01:40 PM
awdriscol4
Dec 18, 2004 10:29 AM
Full Race A6
May 11, 2004 08:06 PM
4door_gsr_ftw
May 13, 2003 11:30 PM
