newaneed help:: my si's engine check light is on but i need to pass smog ASAP!!
Old Dec 16, 2004 | 07:26 PM
b18vtecboi's Avatar
Default newaneed help:: my si's engine check light is on but i need to pass smog ASAP!!
Old Dec 16, 2004 | 07:40 PM
h2392si's Avatar
Default Re: newaneed help:: my si's engine check light is on but i need to pass smog ASAP!! (b18vtecboi)
probably need to replace the cat as i do. Try to reset the ecu by removing the negative battery cable for like 10 minutes then go to get the smog check . ive got a smog hook up who passed my 98 ex with my light on. we just reset it, i drove around for a while then he did his thing then i got my tags if youre interested hit me up, good luck
Old Dec 16, 2004 | 07:42 PM
rob...'s Avatar
Default Re: newaneed help:: my si's engine check light is on but i need to pass smog ASAP!! (h2392si)
if you drive your car for at least 15 minutes you'll fail for sure. also with an obd2 ecu you need to do more than just pulling the - battery cable. if i remeber right o2 codes cannot be erased with out a scanner.
Old Dec 17, 2004 | 09:28 PM
b18vtecboi's Avatar
Default Re: newaneed help:: my si's engine check light is on but i need to pass smog ASAP!! (baseballinmyass
thanks guys, im still looking into how to do it so if theres ne other way feel free to hit me up with a answer. thanks
Old Dec 17, 2004 | 09:57 PM
hadboosttroy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass &raquo;</TD></TR><TR><TD CLASS="quote">if you drive your car for at least 15 minutes you'll fail for sure. also with an obd2 ecu you need to do more than just pulling the - battery cable. if i remeber right o2 codes cannot be erased with out a scanner.</TD></TR></TABLE>
no scanner, just need to drive for X amount of miles without the code being thrown again. i wanna say its 50 miles..
blackouthx
Jul 30, 2007 04:00 PM
sz9182
17
Apr 16, 2007 01:59 PM
khmaitek
Jun 12, 2005 09:28 AM
SYTFU Tommy.
Aug 13, 2004 07:14 PM
charlton
May 8, 2002 10:06 AM
