My attempt at a DIY manifold swap...Didnt work to well
Old Dec 16, 2004 | 03:21 PM
TurboTagTeam's Avatar
Default My attempt at a DIY manifold swap...Didnt work to well
So yesterday I finally got my hands on a y8 manifold for my 97 dx. I was a little weiry about doing it myself. It seemed real complicated but everyone kept telling me it wasent that hard and to go for it.
So...... yesterday i began the swap. First i ran into trouble when I forgot to empty out my coolent.(what a mess) after it was all drained out I dove back into the manifold. Took me about a half hour to get the old one off.
After the old one was stripped of it throttle body it was time to bolt up the new y8 mani. Everything went pretty smooth. The only modification needed was to extend the coolent lines that run to the throttle body.
After the new one was on i filled it up with coolent and attempted to start it.
Didnt sound good. The engine wouldnt turn over. So i double checked everything and tried again.....No GO... Then i pulled the plugs. to my horror cylinder 1, 2, and 4 are filled with COOLENT!!!! I know how it got there. When i forgot to drain the coolent taking of the mani it must have dripped in.
So..... coolent in the cylinders how do i fix this?????
Can the head just be removed and everything cleaned?????
Modified by TurboTagTeam at 5:16 PM 12/16/2004
Old Dec 16, 2004 | 03:24 PM
99hatch's Avatar
Default Re: My attempt at a DIY manifold swap...Didnt work to well (TurboTagTeam)
damn that sucks, now its gonna be a lot more work than just gettin the manifold on
Old Dec 16, 2004 | 03:27 PM
Discosteak's Avatar
Default Re: My attempt at a DIY manifold swap...Didnt work to well (99hatch)
pull out your plugs and crank the motor then let it sit for a couple hours and do it again throw plugs back in and try to start it
Old Dec 16, 2004 | 03:30 PM
klungemonger's Avatar
Is it possible you accidentally put a coolant line onto a vacuum nipple in the manifold? That would fill the cylinders with coolant...
Put a small tube down into the spark plug holes and siphon the coolant out. Don't swallow! It might leak down into the oil pan though, then just drain the oil and change it. You'll know if it drained down there becuase the coolant will be the first thing that comes out the drain hole...
Old Dec 16, 2004 | 03:34 PM
Default Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible you accidentally put a coolant line onto a vacuum nipple in the manifold? That would fill the cylinders with coolant...
Put a small tube down into the spark plug holes and siphon the coolant out. Don't swallow! It might leak down into the oil pan though, then just drain the oil and change it. You'll know if it drained down there becuase the coolant will be the first thing that comes out the drain hole...</TD></TR></TABLE>
There was only three vacum nipples.. One went to the line running to the valve cover and the other one was something to do with the fuel system, and the other was the brake booster line
I attached the two coolent lines to the nipples under the trottle body
Modified by TurboTagTeam at 10:03 AM 12/17/2004
Old Dec 16, 2004 | 03:35 PM
revvin9k's Avatar
Good info, and before you change the plugs you mught as well Seafoam your motor.
Old Dec 16, 2004 | 03:37 PM
Default Re: (S(J)O(D)L(M))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) &raquo;</TD></TR><TR><TD CLASS="quote">Good info, and before you change the plugs you mught as well Seafoam your motor. </TD></TR></TABLE>
Dang i did that did that two days ago! Do it again?
Old Dec 16, 2004 | 03:41 PM
nonsense's Avatar
Default Re: (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">
Dang i did that did that two days ago! Do it again?</TD></TR></TABLE>
if you just did it there's no real reason to again. I think he just suggested that because you're going to have to change the oil too (coolant in oil will kill you engine fast!!!)
Old Dec 17, 2004 | 11:24 AM
Default Re: (nonsense)
Allright so i tried everything, sucked out all the coolant, started with no plugs, let it sit and tried again, Wont start. Think ill put it in the shop tommorow, unless someone has a another idea what it could be??
Old Dec 17, 2004 | 11:30 AM
Does it turn over but not start, or does it just not even crank?
Anything unplugged anywhere? Did you clean & dry the plugs real good before reinstalling them? Make sure you do change the oil even if you got the coolant from the cylinders, as the first thing the oil pickup gets is what's on the bottom of the pan...and since oil floats, that would be coolant.
Are plug wires in correct order on the dist?
Old Dec 17, 2004 | 07:28 PM
It'l turn over but not start. Im sure everything is in correctly. but i didnt change the oil yet so maybe thats it. Ill post the results after i do it
citystars41
Jan 10, 2008 09:58 PM
autoEk
Jul 23, 2007 08:24 AM
Cashieboi
Oct 20, 2006 08:38 PM
Electron00
Apr 24, 2005 11:07 AM
fastcrxsi90
Jan 20, 2003 02:20 PM
