Turbo for 2000 civic
I have a 2000 civic SI and I want to put turbo in it, but I was wondering what I should do to the engine first so that the engine will handle the trubo kit. Should I get cam gears and stuff?
Do a compression test...also read this https://honda-tech.com/zerothread?id=1024174
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danman3323 »</TD></TR><TR><TD CLASS="quote"> Should I get cam gears and stuff?</TD></TR></TABLE>
hmmm. you already have cam gears. why do u want new ones?
I heard from someone on this site that doing improved cams, lifters,and headwork like that on a turbo car is not the correct avenue for performance. I would have to search hard for the thread, but someone correct me if I'm wrong.
correct. stock honda cams are fine. if you want to run your stock block just get decent size turbo and tune it. if you wanna run past 300whp its recomded you upgrade pistons, rods, rings, and possibly valve springs for higher reving. if you want to go to the limit that you can get sleeves but generally for street use thats not really required.
mrbsponge
May 30, 2004 06:15 PM
Rhythm Racer
Jul 16, 2003 08:14 AM
