ECu problem i don't know
I was using jdm life styles thread on ecu and how to check it. went to my car and took a write and did what he did only thig different i found was that i had three plugs one white wire with red strip adn a black wire with red strip and a bably blue wire. I have a gsr Ecu and a b16 sir2 engine. I connected the two slots and the moment i did that i heard an electrical pop. I turned on teh motor adn check all teh lights everythign is fine should i be worried? and if i did blow a fuse which box should i check and which fuse?
I would check all of the fuses... id first check under the stearing wheel for any blown fuses...if not there, there should be some fuses under the hood just pull em' and check em' thats all you can really do.
JDMs1eeper
Jul 6, 2003 06:15 PM
