cut wrong wire
Old Apr 2, 2005 | 04:25 PM
XplodeTeg's Avatar
Default cut wrong wire
I was trying to do the power antenna overide and cut the wrong yellow/green at the driver side. I just found out that wire leads to the ecu which caused my car to not start. My friend connected the wire back and still doesn't start. What should I do about this?
Old Apr 2, 2005 | 04:27 PM
SYTFU Tommy.'s Avatar
Default Re: cut wrong wire (XplodeTeg)
check the fuses. might have blown it also
XplodeTeg's Avatar
no blown fuses
Old Apr 2, 2005 | 04:33 PM
Default Re: (XplodeTeg)
hmmm, might have to restart the ecu and also try to reconnect again. dont getto rigged it with electrical type. go buy some wire connectors.
JDM B20 EH2's Avatar
try reseting the ecu by removeing the 7.5 amp fuse under the hood im not sure but i beleave it is 30 sec you have to leave it out to reset the ecu
Old Apr 2, 2005 | 04:35 PM
XplodeTeg's Avatar
i tried taking out that fuse but dont think i left it for 30 sec. i think i should go wire connecter bc im using tape for temporary.
Old Apr 2, 2005 | 07:56 PM
VINtegra90's Avatar
someone told me that the ecu resets everytime u turn the car off then on
im pretty sure thats wrong... is it?
let me know how u fix ur car
Old Apr 2, 2005 | 09:07 PM
a1320addict's Avatar
Default Re: (VINtegra91)
when i gotta reset my ecu i just disconnect the negative then positive and let it sit for about 10 minutes
jspeccrx91
Aug 11, 2009 05:49 PM
shadow29485
Jun 18, 2007 04:30 PM
zacatkings
11
Mar 15, 2006 08:31 AM
JDMs1eeper
Jul 6, 2003 06:15 PM
JDM CRX
Oct 3, 2002 10:35 AM
