spark plugs for turbo (searched)
Old Dec 15, 2004 | 09:04 PM
coupon's Avatar
Default spark plugs for turbo (searched)
first off, its recomended to run 2 steps colder than the stock heat range right?
so im wondering, if the stock h22 heat range is 6, does ngk make a bkr8e? just like the bkr7e just 1 step colder.
im going to be running around 12psi on the street (since my wg spring is a .7bar) and around 15-18psi at the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Just to add to ladysman post:
6's: 300-350whp level
7's: 350whp-450whp level
8's: 450whp-600whp level
I pretty much use the 7's in everything i tune and run, which is overkill. You'll get better gas mileage and partial throttle response with a hotter plug since it combusts the mixture greater.</TD></TR></TABLE>
12psi would put me in place for the 7 heat range, but 15-18psi would put me in the 8 heat range.
so, since my stock heat range is already 6 should i go with 7's or 8's?
Old Dec 16, 2004 | 05:57 AM
coupon's Avatar
Default Re: spark plugs for turbo (nlc)
up
Old Dec 16, 2004 | 08:59 AM
coupon's Avatar
anyone?
Old Dec 16, 2004 | 09:05 AM
2kflamedlude's Avatar
You will one One step colder. I have the bcpr7es-11
Old Dec 16, 2004 | 09:42 AM
coupon's Avatar
Default Re: spark plugs for turbo (2kflamedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kflamedlude &raquo;</TD></TR><TR><TD CLASS="quote">You will one One step colder. I have the bcpr7es-11</TD></TR></TABLE>
whats your reasoning behind this? ill be making power that would put me into the 8 heat range at the track though?
Old Dec 16, 2004 | 09:56 AM
john d
Guest
Posts: n/a
deciding on the same things, bkr7e or bkr8e
Old Dec 16, 2004 | 10:34 AM
You car ends up running cleaner as in Idle.
Old Dec 16, 2004 | 11:03 AM
SKDRCR's Avatar
ngk part#3330
Old Dec 16, 2004 | 11:16 AM
john d
Guest
Posts: n/a
Default Re: spark plugs for turbo (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">ngk part#3330</TD></TR></TABLE>
isnt it the same thing as #6097 just pre-gapped?
thats still only 1 step colder i dunno....
staticchmbr
Jan 14, 2006 07:29 AM
Devo94ac
Nov 2, 2005 08:53 AM
itr817
Jul 26, 2003 06:10 PM
99turbosi
Jun 9, 2003 11:50 PM
Qwikrex
11
Jan 20, 2003 11:52 PM
