Spark Plug Help
Old Jun 7, 2003 | 01:16 PM
99turbosi's Avatar
Default Spark Plug Help
I am looking for the part # of a NGK platnium plug for a 1999 Civic Si, but one heat range colder than factory . Can anyone help my out with this #, I tried NGK's website and I can't do it there. Thanks!
Old Jun 7, 2003 | 02:04 PM
TKERacer619's Avatar
Default Re: Spark Plug Help (99turbosi)
I dont know but i wouldn't run platinum in a turbo car. It holds heat longer than copper increasing the chance of detonation. I would stick with copper electrode ngk's
Old Jun 9, 2003 | 05:13 PM
99turbosi's Avatar
Default Re: Spark Plug Help (TKERacer619)
Thanks, I did that, I got regular NGK plugs at advanced auto for 8 bucks part #6097.
Old Jun 9, 2003 | 05:27 PM
Joseph Davis's Avatar
I don't think platinum plugs are going to create a hot spot/detonation situation if you get the correct heat range. Not that I really care if they do or don't - you get a better spark from cheap steel electrode plugs.
I use cheapass Densos. Why? Autozone stocks 24 of them at a time, and they never run out of stock... unlike the unobtainium NGK equivalents.
Old Jun 9, 2003 | 07:27 PM
99turbosi's Avatar
Default Re: Spark Plug Help (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">I don't think platinum plugs are going to create a hot spot/detonation situation if you get the correct heat range. Not that I really care if they do or don't - you get a better spark from cheap steel electrode plugs.
I use cheapass Densos. Why? Autozone stocks 24 of them at a time, and they never run out of stock... unlike the unobtainium NGK equivalents. </TD></TR></TABLE>
LOL, how often do you change your plugs?
Old Jun 9, 2003 | 07:28 PM
Flamenco-T's Avatar
once every 5K miles...they're 1.50 each, 6 bucks per change, I am not skimping out on them
stan
Old Jun 9, 2003 | 10:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99turbosi &raquo;</TD></TR><TR><TD CLASS="quote">
LOL, how often do you change your plugs? </TD></TR></TABLE>
Ran the first set of NGK for 8K miles. The past two sets of Densos saw 5K each, and I'm 800 miles into this set. I'm a freak about reading plugs, so it's no especial hassle to pick a set or two up when at the parts store.
Old Jun 9, 2003 | 11:50 PM
mskibbz-T's Avatar
http://www.sparkplugs.com for those of you that are like me and have no local options available.. There is a local shop that sells ZFR7Fs for 5.88/each
Midori Green
26
Nov 25, 2006 05:39 PM
Calean007
May 9, 2005 07:04 PM
LOSERboy
13
Aug 13, 2004 10:56 AM
blackccoupe
Mar 31, 2004 02:50 PM
