walbro 255lph?
Old Dec 15, 2004 | 08:06 PM
92 CIVIC HATCH VX's Avatar
Default walbro 255lph?
ok i'm doing a h22 swap will it hurt anything <including gas milage> to install the fuel pump now even with the rest of the stock fuel system.
<why i ask is i'm trying to narrow down a problem with my car and if this won't hurt then i'm good to swap out.>
Old Dec 15, 2004 | 09:02 PM
dantastic's Avatar
Default Re: walbro 255lph? (92 CIVIC HATCH VX)
you'll need an FPR and fuel pressure gauge. if you set your pressure to stock, it won't affect your milage much.
Old Dec 15, 2004 | 09:14 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: walbro 255lph? (dantastic)
A pump that flows that much fuel tends to overwhelm the stock FPR a little causing the car to run rich, so yes an adj FPR should be used (with a gauge) to set your fuel pressure to a stock setting.
Old Dec 15, 2004 | 10:44 PM
Default Re: walbro 255lph? (00Red_SiR)
FPR's are universal right?
Old Dec 16, 2004 | 08:24 AM
00Red_SiR's Avatar
All Motor Mentor
some of them are but a lot are relatively vehicle specific.
Old Dec 16, 2004 | 04:44 PM
I'm doing the h22 swap and i have the d15z1 motor and want to keep the FPR for this swap also that would be a waste of money if i have to buy a new one?
Old Dec 16, 2004 | 05:19 PM
klungemonger's Avatar
Don't waste your money on an FPR for that D-series if your going to swap. I'm not sure why you were told to change the regulator just because you change the pump. The pump doesn't have much effect on pressure - that's what the regulator is for! Stock regulator = stock pressure.
Even "high pressure" pumps don't make your pressure go up significantly, it just means they can continue to flow high volumes when you increase the pressure, like with a rising-rate regulator some use in turbo systems. The pressure can get high enough to make the stock pump flow decrease right when you need fuel the most!
Old Dec 16, 2004 | 05:34 PM
Default Re: (klungemonger)
that what i thought the stock reg would do but i was not for sure thanks
Old Dec 16, 2004 | 05:38 PM
H22A EG6's Avatar
Default Re: (92 CIVIC HATCH VX)
i got a b&m fpr and the 255lph pump i think it works great on my swap
2lua's Avatar
your h22 swap should come with the fpr.
Old Dec 17, 2004 | 06:30 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">Don't waste your money on an FPR for that D-series if your going to swap. I'm not sure why you were told to change the regulator just because you change the pump. The pump doesn't have much effect on pressure - that's what the regulator is for! Stock regulator = stock pressure.
This is incorrect. A 190 lph pump tends to not affect the pressure regulator to much and the pressure stays relatively stable but when a 255 lph pump is swapped in, it pumps considerably more volume which DOES increase pressure. Because the volume of fuel being pumped is so much greater than what the stock FPR was designed to deal with, it tends to get overwhelmed and not be able to divert the excess fuel back to the tank, so the car runs rich because of excess fuel pressure in the rail. The fuel buildup in the rail increases the pressure from the bottleneck the stock FPR creates.
oxSLEEPERxo
Dec 27, 2005 07:01 AM
VTECisSeXY
Oct 7, 2005 08:41 PM
gsrvtechatch93
Mar 12, 2004 04:33 AM
VTECVillain
Jun 9, 2002 08:02 PM
