Vacuum Lines - Chewed by Rabbit. Where do they go?
Found a rabbit under the hood of my CRX about a week ago, and the following pics sum up what that rabbit had for dinner the night before.
I know where this line goes - from the FPR to the nipple on the IM:
Not sure where the other end of this one goes:
Possibly to one of these two lines that got chewed? Where do these two go?
Here's my throttle cable - you think I should replace it?
Also chewed thru some of the loom and part of a green wire in this section of the engine harness - right below where the tape is. Suggestions for fixing that?
Does this fuel line need to be replaced? It's not chewed thru entirely, I don't think. If I need to replace it, is an OEM piece the best way to go?
What hose hooks up to this nipple on the IM? Is this just another vacuum line? (Must be, since it was just rubber line...)
Thanks for any and all help - I have all day Saturday to get this **** back in working order!!
Alex
Alex
Wish I lived where the CRX lives. If it stays where I live, it gets stolen. If it rests where it is now, rabbits get rocks thrown at them by my Mom
I'm thinking of finding a way of sealing off the bottom of the engine bay with some sort of chicken wire or "hardware cloth"... or maybe I should just drive it more often!!
Alex
Alex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi »</TD></TR><TR><TD CLASS="quote">Rabbit 1 CRX 0
You need to invest in a garage or large dog. - Darrell</TD></TR></TABLE>
or a Bobcat.
or a Bobcat.
The throttle cable is probably unaffected but i'd get a new one because it's fugly.
I'd get a new fuel hose. The pink colored nipple on the tb goes to the map sensor.
For the wire i'd unwrap it all and check it out. Should be pretty easy to figure out. Use solder gun and heatshrink tubing to fix.
My Dad could have fun with my old BB guns, and then have rabbit stew...haha
Yeah, I caught the rabbit in there. I popped the hood, and there was a rabbit basically chillin' right on top of the PCV. I just about shat myself!! The rabbit went flying one way and I stood there with the hood in my hand and watched it's hungry little *** take off into the vegetation. I've found "pellets" (rabbit or rat or mouse crap) in there before, but never any damage - it was a long time ago, after those fires in SD (October 2003).
I decided that for now, I'm going to leave the cover off the car, so the gray rabbits don't see the gray car cover, and think it's a momma rabbit.
Alex
Alex
Also, for the throttle cable - I've got these options on http://www.slhondaparts.com -
17910-SH3-A31 WIRE, THROTTLE $16.36
17910-SH3-A91 WIRE, THROTTLE $18.56
Which one is the right one?
Alex
Alex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si »</TD></TR><TR><TD CLASS="quote">
Yeah, it's $62....do I have any options outside of OEM?
Maybe the Rabbit was a mechanic in his past life, anyways you could get 1 from the junkyard.
It sounds gross, but you can get fox urine from feed many stores and spread it around where the car is and it usually works to keep furry little animals away for a while
id put out some rat poison, i would also put some inside your car,
my mother in laws prelude got destroyed by a feild mouse, it at through all of the wiring inside the car, she went to start it nothing would work, had it towed to honda, spent almost 1500 in having the whole car rewired, mouse **** everywhere also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">
what is this picture from, what manual??
</TD></TR></TABLE>what is this picture from, what manual??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriscol4 »</TD></TR><TR><TD CLASS="quote">what is this picture from, what manual?? </TD></TR></TABLE>
Looks like Helms.
Looks like Helms.
275Performance
Feb 11, 2004 01:06 PM
