Wastegate Question
Old Dec 15, 2004 | 06:51 PM
LSEGHATCH's Avatar
Default Wastegate Question
I am looking into a turbo setup for my civic, but don't know much about wastegates. I am wondering what .3 or .5 spring means and if the wastegate or spring (not sure) says like 6 psi, is that all that wastegate can handle?
I am looking into a 38mm wg and will be wanting to boost around 10 psi, would I need a "stronger" spring for the wg.
Tyler
Old Dec 15, 2004 | 06:55 PM
hybridsol's Avatar
Default Re: Wastegate Question (LSEGHATCH)
Should mean .3 or .5 bar.
1 Bar = 15psi (about), so that would be 5psi or 8 psi.
It has nothiong to do with how much the wastgate will handle.
Use the spring that comes with it and use a boost controller. (you can get a specific spring if you want though)
Old Dec 15, 2004 | 07:02 PM
Adriano's Avatar
Default Re: Wastegate Question (hybridsol)
The spring means that boost is set to whatever the spring is. You can't run boost any lower than what the spring is, but wiht a boost controller, you could increase it.
Adriano
Old Dec 15, 2004 | 07:13 PM
b00sted4dr's Avatar
Default Re: Wastegate Question (brryder)
I think .7bar is around 10psi.
Old Dec 15, 2004 | 10:51 PM
cnydc2's Avatar
Default Re: Wastegate Question (That4drGSR)
I'd get the .5 spring and a boost controller that way you can start at @5psi and can use the controller to bring the boost up 10psi with the turn of a ****.
powerdbygarrett
Jul 3, 2008 01:50 PM
eg:R
Mar 6, 2006 01:15 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
shingles
Jan 24, 2003 01:58 AM
Turbo_Teg
Jan 14, 2002 07:35 PM
