75k motor..what to do before install
Old Dec 15, 2004 | 04:37 PM
rodvang's Avatar
Default 75k motor..what to do before install
I bought a new engine with about 75k miles on it and wondering what i should do to it before I install it..new headgasket, timing belt, water pump and oil pump is what i was thinking..anything else? I will probably boost it later...just about 6-8 psi though so stock internals should be fine with that but im gettin off topic..so anything else i should do before the install?
Old Dec 15, 2004 | 06:17 PM
dinko's Avatar
Default Re: 75k motor..what to do before install (rodvang)
i'd go with a new clutch
Old Dec 15, 2004 | 06:25 PM
PyroProblem's Avatar
Default Re: 75k motor..what to do before install (niann)
Man those engines are just broken in at that mileage. Unless it was abused,Id just do a timing belt,water pump, and front engine seals and maybe the oil pan if its leaking.
The headgasket should be fine unless its already blown and the oil pump is overkill IMO, but then again its better safe than sorry...
A clutch would be a good idea as well as distributor cap/wires/plugs and all the usual tune-up stuff...Tranny fluid also...
Old Dec 15, 2004 | 06:47 PM
PrettyLude's Avatar
timing belt, waterpump, spark plugs, wires, cap and rotor, pcv,
Old Dec 15, 2004 | 08:40 PM
mmuller's Avatar
Mad Scientist
Default Re: (PrettyLude)
i would check bearings too
Old Dec 15, 2004 | 09:28 PM
DohcSide's Avatar
spark plugs some radiator fluid adn some oil and if you have time flood out the engine if the previous ownder didn't already
Old Dec 16, 2004 | 03:50 AM
civic-4-ges's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">i would check bearings too</TD></TR></TABLE>
I agree, I don't know which motor it is, but I had (2) D16y8's die with about 90K on them due to excessively worn rod bearings.
Old Dec 16, 2004 | 08:21 AM
Ketone's Avatar
Default Re: (civic-4-ges)
i would replace the clutch, and get some new spark plugs and wires
Old Dec 16, 2004 | 08:59 AM
Tad's Avatar
Tad
don't forget a new thermostat
JDM00SI
Nov 9, 2005 09:19 AM
SlowDC4
Feb 29, 2004 08:47 PM
jdmgeorge
Feb 18, 2004 12:45 PM
who00knows
Jul 31, 2003 05:39 AM
imported204
Apr 27, 2002 11:23 AM
